Results 1 to 17 of 17
    Invalid Emails
    May 2012
    Golden Valley, AZ
    Default Spyder RT front tire size change
    Does anyone know what size tire for the front you can use in place of the 165/65/r14? I am looking for a good tire for wet, dry and sandy roads with a H rating? To get them without buying the stock tires which one came apart inside with less then 5K on it. I can't find any in the stock size but don't want to have to mod my fenders either? RJ
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Thumbs up Tight fit, but it fills out the wheel well nicely w/o any needed modding
    Feb 2012
    Portsmouth, Va.
    Quote Originally Posted by CyncySpyder View Post
    I too just put these on and like them a lot. Bought at Wal-Mart and they installed, put on new Valve stems and balanced for $11.00 ea.
    Bridgestone Potenzas come in the stock size...
    SpyderLovers Sponsor scooterexpress's Avatar
    Mar 2012
    ft-worth texas
    i put on yokohoma 175/65/14 no adjustments needed got them at discount tires.79ea
    Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    I put 175/65R14 Michelin Defenders on mine. They have a 'T' speed rating (118 mph).
    http://www.tirerack.com/tires/tires....omCompare1=yes
    By the way, I have found www.TireRack.com to be a good source of information on many brands, including testing and reviews. I use it as a part of my research when considering new tires.
    Default I JUST FOUND THIS TIRE SIZE ???
    I didn't even know they made this size 185/55-14.......I don't know what the circumference or width is but I am going to find out.....Nice looking tread pattern and " V " speed Rating........Mike.........It's a Yokohama S.Drive $ 77.86 @ onlinetires.com--------Just put in the tire size and it will go direct to this tire + 4 others.........More info the circumference = 945 revs per mile vs. OEM @ 926......and the width will fit under the fender.....The big difference is the footprint of this tire is HUGH 6.7 INCHES and only a hair wider than the 185/60-14.....The OEM tire only has a 5 inch footprint.
    western Colorado
    OMG! A half NakeD
    Default BUMP
    Default There you go...!!
    and that is just a few..!!
    Sep 2011
    Waleska, GA
    Default Different sized front tires
    Do you folks with the bigger footprint tires notice any significant handling differences from the OEMs? With a stiffer set of tires, I'd imagine something would show up. Then again, what do I know?
    Tuck
    Default YOU MAY LOTS
    Quote Originally Posted by TuckMiddle View Post
    Tuck
    Tuck, I haven't made the purchase yet on the Yokohama's ( 185/55-14), but the tire specs lead me to believe that that is the largest footprint of any tire that will fit under the OEM fender...Footprint equals increased lateral traction ( for front tires) and more-so on the BRAKING ability. The people who race bicycles ala TOUR DE FRANCE can very very easily lock up their wheels because they have almost NO RUBBER CONTACT on the road.....Granted a larger tire footprint can more easily lead to HYDRO-PLANING but this can be mostly controled by the operator by just slowing down.......at any rate I'm going for the bigger footprint....Mike...
    Sep 2011
    Waleska, GA
    Thanks, let me know how they work out, please.23
    I wrote a note yesterday about my Kumho rear
    It does great with no hydro planing, but it has done some dances on an aggressive start on wet surfaces
    Did a big time one on Wed on an on ramp to I75.
    That was the 4th time, others on county and private roads. The originals never did that - two tires in 28000 miles
    Tuck
    I am not a throttle jockey so it was a surprise. I was wondering about hydro planing due to the wider,stiffer tire with less weight on it.
    Active Member Y-me's Avatar
    Feb 2011
    NY
    Quote Originally Posted by happyspyder2039 View Post
    OMG! A half NakeD
    Tuck, What year is your RT?
    I like your flying saucer too.
    Sep 2011
    Waleska, GA
    2011 RTSM5
    Chattanooga TN
    Tuck
    Thats a concern as I am about to install a new Kumho on the rear and have never had traction problems with the oem rear....
    Anyone else have a similar experience losing rear traction, either with the Kumho or other car tires on the rear ?
    Is the Toyo likely to be much better?
    May 2018
    Arizona
    Default Run flats on a 2012 RS Spyder
    The Altimax tires look fantastic I wonder if they would fit my 2012 Spyder RS with a good fit and not rub the fenders, but has anyone found and put on run flats for the front and rear tires? Any recommendations close to stock sizes?
