Did they give me the right screw driver?
Hi all,
I just received my 3 piece net set from Value Accessories.
I am excited to install them. the screws on the inside of the side bags on my RT use these funny star-headed screws ( I know you know what they are called). In the tool kit, they provide a cool double-sided driver with that kind of head. Only, it seems to small to turn the screw. If I do, I think it will strip it.
Anyone know if they included the proper driver, or do i have to go out and find one?
Thanks!
it requires a T20 Torx Bit Driver
Get a cheap set at Home Depot or Lowes or some similar hardware store
Cruzr Joe
They are Torx screws. A set of screwdrivers is not very expensive and I suggest you get a set.
![](signaturepics/sigpic7798_4.gif)
Torx set...
Sears sells a very nice "T" handled ratchet set that includes Torx™ bits.
I only looked in my tool kit under the seat once, does it have Torx drivers in it? I'm away from the Spyder so I can't look...
JT
![Quote](images/misc/quote_icon.png) Originally Posted by jthornton
JT
Yes, Screw driver handle with double ended shaft.
