View Poll Results: Quality Survey Part II
- Voters
- 97. You may not vote on this poll
You feel problems with brand new Spyders are primarily due to faulty dealer prep and assembly.
You feel problems with brand new Spyders are QC issues during manufacture
You feel problems with brand new Spyders are mostly owner ignorance (newbie)
I choose 2 even with spyderpops block off plates my foots still warm. Gonna look for some reflective duct tape to seal the little gaps where it seeps out. Design flaw least in the lower 48 no?
Sent from my home in Central Texas!
2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
All of the above
You left out all of the above. My complaint is they don't tell you how to ryde it. Every bike I have ever owned had shift points in it. They don't tell you that you should run this vehicle at or above 4000 rpms. Every important thing I learned about the Spyder was on here. This forum. I have read the manuel from front to back. That is just my humble opinion.
A blowed-up engine (#3!), after a turbo was installed...
We just dont' know when to quit; do we?
Yes, I know when to quit...
Balljoint replacement.
22ozs overfilled with oil. Tank completely filled.
Cruise control switch intermittent.
BOTTOM LINE
You have to have a good dealer, or you are majorly pooched.
Hmmm somewhat of a catch 22...There are some design flaws which CAUSE us to mod and farkle which then cause other problems.
In my case I went with dealer...when I got mine home all tires were VERY low, oil almost a quart overfilled and zero air pressure in airbag. Wouldn't have been a big deal except for first time rider and dealer being 150 miles away.
Squeaky wheel...
Originally Posted by Chupaca
Have to say they all apply but to put them in order I'd have to say #2, #1, #3. JMHO...
Based on the trend of the poll, why not have a 2 part dynamic check list. Part 1 would be done at the factory with required hot tests/checks or the Spyder does not leave the factory, period. Part 2 must be done in a consistent non deferable dynamic regardless of dealer or the Spyder simply will not start. This would seemingly generate consistent quality.
This raises another question. Where in the pre-production scheme would you find bad throttle bodies and ball joints before they hit the production line?
never mind all of this right now...
WHEN is your test ride scheduled for??
Tomorrow at 11:30 am. ASK Brice Road Columbus, Ohio
Dealers full of crap
Well after all we are all in for the ride think positive and only good things can happen,see u on the road and be safe!
Originally Posted by bullant12
Although most of the issues ocurre in the factory, it is up to the dealers that the machine is in working order and preped up before customer delivery. QC involves the dealer since they are the ones that finish assembly and are instructed by BRP to test it before delivery. So it is a combination of 2 and 1.
Well said
cheap
just out right cheap quality build of the machine how ever mostly the plastic cheap way the body panels are connected is a prime example plastic push pins on a $25k bike why not at least plastic heavy duty screws its a company that only cares about the sale and not the service for the owners
Did you do ANY research before purchase or did you buy on impulse?
simple vs quailty
I rather pay more and have quality then simple as your thinking
Sorry Doc...
I wasn't aiming at you with the last comment...
I probably shouldn't have said it though!
All good buddy, just saying...
Noob to Spyder
I was A new and used car salesman in a prior life. The #1 thing I learned, especially new, was taking the time to go over the vehicle with customer was instrumental to having a happy customer. One, you are able to find items that prep missed somehow. This didn't happen often. Two, it gave the customers an opportunity to ask questions. It is not good just to send the customer back to service and have them 1/2 ass go over things which is what happened to me. I really appreciated Spyderlovers for their help and info!
