Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 76
  1. #26
    Active Member zbunker's Avatar
    Dec 2011
    Altamonte Spgs, FL
    Default ordering the bumpskid
    Quote Originally Posted by diesel-dawg View Post
    thanks guys for the input....very informative. Needless to say, I am ordering the bumpskid.
    Hi,
    May I ask where you are purchasing the bumpskid? I look at the vendors on the site and unless I missed it, do not see anyone who sells them. Thanks Ron
  2. #27
    Big Rig Member
    Apr 2013
    Calabash, North Carolina
    Quote Originally Posted by zbunker View Post
    Hi,
    spyderpops.com is the place. They had it in shipment almost immediately after placing the order.
  3. #28
    Invalid Emails
    May 2011
    Scottsdale, AZ
    Default Bumpskid....is it needed?
    What about aquaplaning?? I am afraid this big flat plastic piece will act as a surf board on any puddle!
    I'd love to have a metal plate under the engine.
  4. #29
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Quote Originally Posted by prmurat View Post
    I haven't had any surfboarding. The frame is under the engine. Don't think metal will do anything for you other than add excess weight.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
  5. #30
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    If your driving at speed in 6" of water you will have other things to worry about instead of hanging 10.
    JT
  6. #31
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by jthornton View Post
    JT
    Amen, brother, amen!
  7. #32
    Oct 2010
    Somewhere out there...
    Did anyone in Spyderfest take a picture of the OEM plates that Spyderpop removed before installing the Bumpskid Plate? Some of them made me wonder how the still had a front end!
  8. #33
    Jun 2012
    Greenfield, MA
    Yes I have one and it save my Spyder's front end. You will love the plate
  9. #34
    Big Rig Member
    Apr 2013
    got my bumpskid delivered today. spyderpops.com surely is on top of his game. Great service on this order.
  10. #35
    Jan 2013
    San Diego area
    Red face bumpskid
    I wasn't sure if it was needed but bought one and when I installed it and when I saw the condition of the factory skidplate realized that it was a very good and wise investment.
  11. #36
    Active Member donnellpj's Avatar
    Sykesville, MD
    It was the first mod I put on the bike.
    I have used it, it works, and I would do it all over again,... and it looks great to boot!
    The thing is, the skid can be replaced if it gets damaged too badly, the nose of your bike is a little different.
    2014 Spyder RT Limited , OEM NA Satin Platinum
  12. #37
    I don't know that the Bump Skid is necessary if you mean you can't live without it. But I can say for sure that you're much better off with it installed. It's more than just a piece of plastic. It is well thought out, looks good and is very functional.
    It is the 1st piece of your Spyder to hit an obstruction (be it something at speed on the freeway or a wheel stop in a parking lot). Without the Bump Skid installed, a nicely painted, expensive part of your Spyder will take the hit.
    The Bump Skid is well worth the money. Highly recommended!
  13. #38
    Active Member Squadcarman's Avatar
    Sep 2011
    Lino Lakes, Minnesota
    Default Saves the frank
    I hit one of those highway alligators with mine. I'm sure I would have had a lot of damage without it. It helped my rt slide over the tire chunk and keep control.
  14. #39
    Sep 2011
    Default Saves the frunk
    Works better than auto correct
  15. #40
    Active Member soaring hawk's Avatar
    Feb 2011
    Mankato, Minnesota
    Default Is it worth it?
    I had one put on spyder fest last year, well on the way home foggy rainy didn't see a dead armadillo when thump crunch we ran it over , bump skid paid for itself in 5 miles after spyder fest 2012. Saved the frunk ! It's worth every penny!
    Gary
  16. #41
    Bryant, Arkansas
    Well i think you get the picture here................ Get a Bumpskid.
    Cruzr Joe
  17. #42
    May 2012
    Fort Myers
    Quote Originally Posted by SilverSurfer View Post
    Within one week, I improved handling and mpg on my RT:
    Bump-Skid (critter splitter) - In addition to protecting the front underside of the nose, the unit seals a big cavity from the front to the rear of the front, stopping just in front of the suspension, a space subject to air drag under the Spyder. Gone. Less 'sail' from the faring. It also amplifies some down pressure on the front of the Spyder when at highway speed ... stability. Better aerodynamics = better mpg.
    BajaRon's Sway Bar. Installed along with Bump-Skid. Combine this with my front Elkas Shocks ... The Spyder is on rails.
    BRP Can/Am Spyder Sport Touring Vented Windscreen - reduced windsreen profile by 2" vertically and 3" horizontally. Less wind resistance and less buffeting. Helps highway mpg
    Regarding mpg, the Spyder is always (and affectionately) a gas junkie when moving around streets and neighborhoods. The combination of the bumpskid and sport touring vented windscreen have my highway mpg up to 34/35 mpg solidly, riding one-up at 199 pounds without cargo. Mpg on the Spyder is strongly affected by passenger weight, two-up/one-up, trailer/cargo weight and other variables. The aerodynamic, and modest fuel economy improvements offered by the Bump-Skid and windscreen modifications, in my opinion, are most optimal at highway speeds (50 mph and over). Otherwise, the greatest influence on Spyder mpg is rider/passenger weight and cargo.
    I've put most every mod I could and I've been resistant on the bumpskid because with the Elkas and shock relo kit I'm sitting pretty high. This is the first post I've seen espousing aerodynamic benefits. I noticed you put the sway bar on at same time. Do you think that had more to do with handling improvements?? I've got everything else you have including sway bar and sport windscreen. You definitely have me reconsidering this, thx
  18. #43
    Short of this.... You should be fine.
  19. #44
    Big Rig Member
    Apr 2013
    I just completed the install of the bumpskid on my new RT LTD. Great piece of work by Spyderpops.com ... The screws sent for the installation work fine for the front, but were too short for the rear installation, as you need some grip to be able to mold it a little. I went and bought 4 each #6 metric screws, somewhat longer than was included by Spyderpops. Other than the screws, it was to my liking; I think it will do the job! To avoid damaging the edge of the skid, it seems like a hardened rubber rim would be an additional thing that should be designed into the bumpskid.
  20. #45
    Nice picture, Ron!
    Oh! I got to looking at my OEM plate while I was crawling around inside the front end with a RonBar in my teeth...
    That sucker is already pounded into oblivion!
    The BumpSkid is real high on my list for sure!
  21. #46
    Nov 2012
    Plano, TX
    Default Me lika me bumpskid!
    Nothing was cheap at SpyderFest. :P But had to get the BumpSkid from Pops. I was a wus and trailered my bike up/back from TX.
    I had it strapped down on the open trailer. On the way back, I noticed in the mirror that the front straps were 'slack'! I pulled over and sure enough, the rear strap had broken and the bike had moved forward, going into the front rail/wall. Needless to say, there's a small ding/notch in the BS now BUT no crack or damage to the front plastic or frunk!
    Was obviously worth the $. Have been busy since being back so haven't ridden enough to warrant comment on performance of it, but it surely can't hurt!
    J / Roof Man
  22. #47
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by JsSpy View Post
    J / Roof Man
    Having towed more bikes than I can count, over more miles than I can count, I can only say one thing...
    "Double up on the tie-down straps...always!"
    Straps break, move, or can snap in a collision. Two sets of straps is much cheaper than repairing your ride. I learned that the hard way, a long time ago.
  23. #48
    Apr 2012
    Hooper, Utah
    Default Great Investment.
    I installed the Bumpskid today, I was surprised how much the bottom was scapped in only 800 miles. It was an easy installation.
    I did remove the ribs along the edges so the plate fits better.
    it looks good and I think it will improve fuel mileage. On just a short test after installation it feel solid in the front.
  24. #49
    Jun 2011
    Texas
    Is it necessary to lift the front end to install the bumpskid?
  25. #50
    Big Rig Member
    Apr 2013
    Quote Originally Posted by dshogman View Post
    Yes, it was necessary for me, since the front end is so low. I went to Harbor Freight and bought a set of their metal tire ramps for about $40. Simply drive each front tire up on them and set the parking brake. Ready to install the bumpskid...
