Results 1 to 12 of 12
    Jun 2011
    Donaldson Arkansas
    Default Leaving Monday and NO START!
    Leaving in the morning for spyderfest so this morning I went out to do last minute checks. Went to start her up to warm so I could check my oil... She fires up and sounds like she was running on one cylinder. twisted the throttle and nothing, no response. she dies and try restart, same thing but running worse then retry LIMP HOME!! Throttle body codes!! AGAIN!! Let it set for a minute and she fired up like nothing happened. Hope she will get us there. Already had to change out the throttle body less than a year ago. Hope Pittbulls will be able to look at it when we get there.
    Aug 2012
    Semmes, Alabama .
    Not cool.
    Bryant, Arkansas
    another reason to ride with other folks. NOT PICKING ON YOU
    Cruzr Joe
    Invalid Emails
    Alberta, Canada
    Quote Originally Posted by Farmboy View Post
    Maybe get a code now in case it does not happen again, plus you can see what did happen and plan from there. Don't want to get stranded. This would definitely be my luck too.
    Jun 2011
    Donaldson Arkansas
    Got her packed and just now got back from a ride. All good for now. Leaving in the morning hell bent for Mo.
    Wishing you a safe and uneventful trip.
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Good job! Have fun!
    Default Good luck..!
    be careful, be safe, and enjoy the fest..!!
    Dec 2008
    Jacumba, CA
    A Throttle Body is not a life or death issue on a trip. Once the Spyder has been started for the day, use your kill switch only any time you stop. That way the computer does not need to be used again and all you have to do is hit the starter button (DO NOT turn your key off after you use the kill switch!) I rode this way for 6 months before changing the TB.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Dudley View Post
    Whoa, wait a minute; you mean the kill switch essentially works as if the key is turned off and theres no drain on the battery? Been riding for 60 years and never knew that.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Jun 2011
    Donaldson Arkansas
    Has to be referring to like stopping for gas or something.....
    Motorbike Professor
    Mar 2008
    Allegan, MI
    There is drain on the battery. The kill switch mainly kills the ignition and a portion of the displayed information. Not a good idea to leave things like this and go into the restaurant. The Spyder might not be there when you return.
