Results 1 to 15 of 15
    Invalid Emails
    Sep 2012
    Middlebury, CT
    Default Trouble Shifting My RT SM5 Into Gear
    Started my 2012 RT SM5 yesterday and had a lot of trouble shifting. I could not get it to go into reverse or neutral. I had shut the engine off to get it back into neutral but as soon as i start it up it wont shift. I tried this a few times with the same result, wont shift unless i turn the bike off. The check engine light came on after about 4 attempts. I pressed the mode, set and blinker buttons simultaneously to see if there were any codes but nothing comes up on the screen. Anyone else ever experience this issue?
    Springfield, MO
    How's your oil level?
    Invalid Emails
    Sep 2012
    Middlebury, CT
    Oil level is good...
    Springfield, MO
    I just reread this and see that it is a SM not a SE. I'll have to think about that one.
    Springfield, MO
    It's pretty much got to be in the clutch plates, sounds like they may be warped. The only way to know for sure is to tear it down.
    Invalid Emails
    Sep 2012
    Middlebury, CT
    Just tried to start it and it was a little sluggish starting. Can a low voltage from the battery cause this? I don't have a battery tender on it.
    Invalid Emails
    Sep 2012
    Clermont Florida
    Im guessing from your post you do infact have a manual shift with clutch and maybe your clutch resivure is low on fluid not enough to disengage the clutches,check to see if you have a leak or you have clutch disegagement.
    Mike
    Invalid Emails
    Mar 2008
    Ludington MI
    Motorbike Professor
    Mar 2008
    Allegan, MI
    I'm guessing that your slave cylinder has failed. This is a recurring problem that is being investigated. You will have to replace the slave piston & O-rings, and the slave bushing (cylinder) and O-rings. Cost of parts is about $80 if it is out of warranty. You will recognize the problem by discolored clutch fluid, due the the aluminum that is sluffed off the slave cylinder as it wears, and the deterioration of the O-rings. Be sure to thouroughly flush the clutch system when you do the work. If the clutch fluid is clear, the first place I would look is warped clutch plates, as Lamont said. There is a newly revised clutch pack available, with steel plates and 5 plates/discs. Be sure they order the one for the SM...the SE clutch kit is different. Time to see your dealer.
    washington state
    How many miles you have? Let us know the repair entails. Sorry to hear this happen to you.
    Please keep us posted and let us know what you find out.
    Invalid Emails
    Sep 2012
    Middlebury, CT
    Ok, I charged the battery up and checked the oil level again, it was just below half way which is still within operating range. I topped off the oil. and started her up. Started much easier and no check engine, went into gear no problem. Cant take it for a test ride because of the Blizzard we are having, but maybe by Sunday. I left a message with the dealer to look at it to make sure. Still under warranty. Thanks for everyone's help. The Best people make the Best Forum. SPYDERLOVERS
    Invalid Emails
    Sep 2012
    Middlebury, CT
    I forgot to mention, I also installed Ron's Sway Bar today. Can't wait to try that out. Thanks Again
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by Tin Man View Post
    Glad to hear that it was something simple and easily fixed.
    2018 F3-T
    2018 F3-T , Pearl White
    Active Member Navy Warrant's Avatar
    Huntersville, NC
    BRP now retroactively provides road side assistance for 2012 and newer Spyders. Call them if you have any more problems. They should pay to get it to your dealer.
    [/IMG]
    2012 RT-S SE5, Pure Magnesium Metallic (traded in)
    2015 RT LTD SE6, Red Pearl, Ultra Comfort Seat
    MODS: shorty antenna, BajaRon sway bar, Air Hawk cushion, custom LED US flag, custom Sue Hopper painted SPECOPS hood logo, custom Combat Craft Crewman windshield engraving, cup holder, Doc Humphry's 2017 complete RT kit belt tensioner
