Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
  1. #26
    Check this out!
  2. #27
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Marker View Post
    For the spyder you need to use the Krikit 2 gauge Napa Parts #7401-0102
    The one you mentioned is the krikit 1 for v belts.
    The larger gauge is for multi-rib belts to a maximum of 14 ribs. As stated on the video. It is not recommended for tooth type belts as is on the Spyder. There is a warning on the Gates web site not to use this gauge on timing belts. (Tooth type belt)
  3. #28
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Do you push up on the lower belt run or push down on the top belt run, or doesn,t it matter if the rear wheel has been raised off the ground?
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
  4. #29
    Jun 2012
    Hampton, Virginia
    Default Gates 91132
    Based on my researching past posts on belt tension it appears that the Gates 91132 is the proper Kriket gauge to use to check belt tension. RockAuto.com has them for about $14.00.
  5. #30
    Jun 2012
    Alberta
    NAPA part # KR2 is the proper part number for our needs.
