Results 1 to 11 of 11
    Jan 2013
    Northern Illinois
    Default Green Aur Filter Worth it?
    I have read about the Green Air Filters. I believe that you can get increased hp and tourque with more air flow, but not great amounts. Has anyone had positive results with this to justify $65?
    Jun 2011
    Lynden, WA
    I have seen no improvement with the green filter.
    Chattanooga TN
    I have used both Green Filters and K&N Filters in the past on several different vehicles including 2 RTs. Every time I get one, I ask myself why I wasted the money! A good paper filter probably does a better job all around.
    Default Durability...
    You can wash and reuse them. Not enough improvement by themselves but in combination with pipe etc. Noticeable..
    Nov 2010
    Norway, IL.
    I have a Green on my RT, a K&N on my GMC Sierra, A K&N on my 69 Bonneville and a K&N on my Yamaha SR 500. Some power increase, long interval between cleaning.
    You aren't going to see any difference with just the air filter. As mentioned above, coupled with a good exhaust and fuel management system you may get 5-8 more HP.
    The main improvement is you don't have to dig into your air box very often and after a few paper filters they start paying for themselves.
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    Not sure on my Spyder, but the K&N's I've put on all my cars and trucks for over 35 years seem to make them breathe easier. When I put a set on my Yamaha 650, I had to re-jet the carbs because the filters lean it out too much. That much more air was coming in.
    Then there is the factor of not buying another for years....just cleaning it.
    Active Member Recluze's Avatar
    Jan 2009
    St george, UT
    I had a green air filter on my first Spyder. The only difference I noticed is that it made noticeably louder. I use paper ones now.
    http://bobspyder.wordpress.com/
    #610 2007-2009
    #104 2012....
    Ultimate Spyderlover
    May 2012
    McComb, MS
    For Power?.....worth it if you have a pipe and tuner to go with it.
    For servicing....worth it because you can clean and don't have to service it as much.
    Jan 2013
    Northern Illinois
    Added power and increased sound are good things. I would be pairing it with a Two Brothers pipe and Juice Box. It's honestly just fun to spend money on your toys, let's just admit it!
    martinsburg,west virginia
    we put after market exhaust and the k n h air filter and our power went up and our fuel mileage increased maybe 4 mpg...best part is just wash the filter ... its a one time charge...how ever if you do the air filter , you almost have to do the exhaust because your air flow changes a lot, lots of air in, restricted by stock exhaust comin out...plus i love the sound of my pipes!!!!
