Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 100
  1. #51
    Thinks out loud
    Apr 2012
    Quote Originally Posted by dave01 View Post
    They have 1 week till I go on vacation. Never drew a line in the sand before but I have now.
    If they have a good spark chaser and allow him the time needed to shoot the problem. He'll find it.
  2. #52
    Invalid Emails
    May 2009
    Clearwater Florida and Frankin NC
    Well, they are working on it at a quick pace. Pulled relays, checked wires, draw testing etc. Basically, everything they hav done before. You never know, it might just work.
  3. #53
    Morristown
    You may want to try an old trick we used on boats. Disconnect you negative battery cable connect test light to battery, connect other end of test light to negative cable. If there is a draw test light will light dim if it lights up disconnet one thing at a time until light goest out, when it goes out you found a draw it that circuit. Hope this helps.
    Larry (wormie)
  4. #54
    My Brother-In-Law is in the Navy and he said he could fix your problem... He just needed the address of you dealership. I was sure you wouldn't mind.
    He didn't say what he was going to do... Guess he's going to make a phone call or something.
    He said to tell you not to worry about your Spyder anymore.... Everything will be taken care of shortly...
    Please! Don't thank me! Just a good buddy lending a helping hand. Afterall, what are friends for!
    Oh, and my B-I-L said you might want to look for a new dealership... Great guy but he says that strangest things...
  5. #55
    Invalid Emails
    May 2009
    He said to tell you not to worry about you Spyder anymore.... Everything will be taken care of shortly...
    That was great, Thank You Ron
    Is he accurate? I live real close to the dealership. Maybe time to go to the mountains. LOL
  6. #56
    Invalid Emails
    May 2009
    Back to the dealership today. They sure do have a nice waiting room. Free coffee and many bikes to look over.
  7. #57
    May 2008
    Clearwater, FL
    Look for Spyders only...
  8. #58
    Invalid Emails
    May 2009
    Quote Originally Posted by docdoru View Post
    Doc, they have 3RTS, 2RSS and 1 RS right outside the waiting room. I have been sitting on all of them. HMMMMM, auto-shift sounds good.
  9. #59
    Apr 2011
    GREENVILLE, SC
    Electrical gremlins can be tough. They are very good at hiding from the tech and coming out as soon as you leave the shop. Here is what I'm afraid of. You sell it, taking a beating as you say, the guy takes it somewhere, they find the $3.00 gremlin and he's sailing home free! I've seen it happen!
    You endure the misery, he reaps the benefits.
    Again, here's hoping you get that sucker this time. We're all rooting for the good guys to win this one!
    BINGO on that.... i gave my son-in-law my SEARS lawn tractor, because after ten years, it would nolonger start - DEAD AS ROAD KILL, as they say... i went out and bought a new JOHN DEERE, and my son-in-law comes back to me and said he found a burnt our fuse, replaced it for $0.40 and it runs like new.... i crawled all over that thing and never saw a fuse, but i guess my lose is his gain...
  10. #60
    Jan 2009
    austria
    Unhappy
    last winter my RT stood 5 month without a batterie tender .. startet without any problems .. what are you doing over there
    29.000 kms now ...
    greetings from Austria
  11. #61
    arntufun
    Guest
    Hypotheticly speaking if this was not under waranty........
    Couldn't this be cured easily if you installed a toggle switch off the battery and ran it up to the dash to mount it before power ever reached the harness ????? Sure your clock would never be right, but that the only downfall I see with this method.
  12. #62
    Nov 2011
    Las Vegas, NV
    Default The MOST unreliable POS I have ever owned
    Quote Originally Posted by arntufun View Post
    Might not save the user settings either.
  13. #63
    And it shouldn't have to come to that anyway!
  14. #64
    Invalid Emails
    May 2009
    Thank You Bob. I could not agree more.
  15. #65
    Not that easy, and really not the way to go after the problem.
    You would need much more than just a simple toggle switch to carry the amperage required.You'd need a heavy duty relay that actually carried the load and the toggle switch would work the relay.
    Bottom line is, there is something very wrong here and they just need to fix it. I'm sure it's a bear because, like I've said before, it's s gremlin hiding somewhere and there are a lot of places to hide. He only comes out when no one is looking. Gremilns would not be gremlins if they were stupid!
    I'm rooting for BRP, the dealership and Dave on this one!
  16. #66
    arntufun
    Guest
    Sorry guys, I should have been more clear about what I was trying to say.
    I'm not saying Dave should do this, I was trying to say (Hypotheticly) if the Spyder was out of warranty and I had no money to keep sending it to the dealer I would install a toggle switch even if I needed a relay to make it work. I understand that he should not settle for this Goldburg fix since his Spyder is still covered under warranty. Sorry, if I confused anyone with what I was trying to say.
  17. #67
    Circleville,Ohio
    Default Battery drain?
    Is every load on the battery fused? With the bike shut off, pull the fuses one at a time. Insert a suitable amp meter across the gap where each fuse is plugged in. If it shows a current draw, there's your problem.
  18. #68
    May 2010
    Knob Noster, MO.
    Dave01,
    You need a gremlin bell. If you PM me an address, I have one I will send you.
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
  19. #69
    Motorbike Professor
    Mar 2008
    Allegan, MI
    What would really be needed would be a battery disconnect switch, like those required on race cars.
    The RT has a certain amount of necessary parasitic loss, so it would not like a complete disconnect. It is best to find the cause of the excess parasitic loss or battery discharge, and cure it...not matter if it is on warranty or not.
  20. #70
    Invalid Emails
    May 2009
    Quote Originally Posted by Blue Star View Post
    Dave01,
    i HAVE ONE, mAYBE i NEED 2 OF THEM. lol
  21. #71
    Invalid Emails
    May 2009
    Quote Originally Posted by OldDog View Post
    Been done. The big issue is it doesnt do it all of the time. Not sure if it is heat related, vibration related etc.
  22. #72
    Circleville,Ohio
    Go back to the Car wash! Bear with me I'm just joking. I can certainly understand and appreciate your frustration. You have way more patience than I. Patience is a virtue. Have any wiring harnesses been disturbed in such a way that there could be insulation rub through?
  23. #73
    Motorbike Professor
    Mar 2008
    Allegan, MI
    I suspected that was the case. Pulling the fuse or relay may even clear the problem (like a sticking relay) and make it harder to locate. I think at this point replacing all the relays would be a good place to start, especially the load-shedding relay.
  24. #74
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    Are they sure that your spyder isnt over charging,something is damaging your batterys and overcharging sure will
  25. #75
    Invalid Emails
    May 2009
    Quote Originally Posted by Gordy View Post
    It is supposed to be charging the correct amount. Lots of checking, re-checking of parts and I am not sure but I think I saw a crystal ball in the corner and they were all sitting around it at lunch.
