Page 1 of 3 123 LastLast
Results 1 to 25 of 68
    Aug 2012
    SD
    Default Seal Floorboard Problems
    These can be great boards but read the install instructions carefully. I have a 2012 Limited and they do not fit that great. If you need to raise the passengers footrests then you will have to make your own support to hold the rear bracket solid. These rear brackets are made to have the passenger footrests down all the way to make the rear bracket solid. Also just discovered that I will have to put risers underneath the front supports to keep them off the wings under the front part of the floorboards. Any pressure at all on the the top front of the boards hits the wings. It has turned a 30-45 minute job into 8 hours.
    Jun 2010
    Durham, NC
    Quote Originally Posted by rrfreng View Post
    Call John @ Seal I am sure he will work with you to resolve any issues you are having! I don't have his stuff, but I have had lunch with him and he is a great guy!
    magical member
    May 2012
    Bellingham MA
    John has some update rear mounts for this issue. They are square in nature so the don't twist.
    The front of my seals don't touch the front wings? maybe with the new rear brackets this will sort list self out.
    Contact john he wil get the new brackets out to you.
    Here is the thread on the new brackets.
    harry
    Palm City Florida
    I installed Seal Floorboards 4 weeks ago.I have a 2012 RT.I am not handy at all but I followed the instructions and had the job done in 45 minutes.It was no problem and have done a 1000 miles with them .They are terrific.
    I simply cannot imagine it would take anyone 8 hours to install.
    Ivor
    Jun 2012
    Nevada
    I installed mine a few weeks ago and noticed the same thing with rear foot rest,
    I saw on his web site about the new rear pegs for the rear but did not get them
    when i ordered mine.
    My problem however is the rubber mat keeps sliding around in hot weather, I removed them, cleaned the surface good and re silicone them
    but they are moving again so might have to find a better glue.
    Overall I love the floorboards and would buy them again.
    Palm City Florida
    Quote Originally Posted by leenanj View Post
    I had the same problem went to Napa bought the 3 m spray glue.Cleaned them up ,sprayed the 3 m now they don't move at all.
    Ivor
    John's a guy who stands behind his product 100 percent... Call him and he'll do whatever needs to be done to make sure that all is as it should be for you...
    Active Member schnauzermom's Avatar
    May 2012
    Renton, Wa
    Default LOVE SEAL FLOORBOARDS
    Love the floorboards, great product!! Since we're on the subject, my husband was thinking of removing the rubber mat and taking them to Rhino Liner and have them sprayed with the liner instead.....anyone ever done that, see any potential problems with doing that????
    Aug 2012
    SD
    I do have the square rear mounts and they slip out of the rear unless you have the passenger footrests all the way down. I need them all the way up!
    It doesn't take 8 hours to install UNLESS you have to MAKE your own supports to hold the rear mount in and down!
    I was also including the time it is going to take me to remove the front supports and put risers underneath to keep the front of the boards off of the wings.
    I have installed MANY after market upgrades to many different motorcycles and never have had this many problems in the past!
    I am not sure if this may only apply to the 2012 Limited RT SE5 version.
    magical member
    May 2012
    Bellingham MA
    I have a 2012 RT Limited.
    If the front of the sealboard is screwed to the front peg, how can the rear pull out? the angle needed can not made.
    Can you take some pictures or small video showing the issue be nice to help you if we can.
    harry
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Question Interesting. .............. Have you contacted John?
    I realize this is a great forum to find information and also to vent for those of us that feel no one is listening to our problems but I find it difficult to understand why someone would post negative comments about a product or service before giving the manufacturer a fair chance to correct any issue or problem Just my 2¢
    Jun 2012
    Nevada
    Quote Originally Posted by harrypottar View Post
    harry
    It cannot fall out but it can move or flex up and down when stepped on.
    It also vibrates somewhat because it is not attached firmly.
    I was thinking of drilling the rear bracket out and putting a bolt through it, problem solved.
    Aug 2012
    SD
    How do you know I haven't contacted him? I Have! I was told the rear passenger footrests must be placed down on the rear supports!
    Then the rear brackets are solid. I NEED THEM ALL THE WAY UP!
    Maybe some people don't know what they are talking about!!!
    Aug 2012
    SD
    To fix I used a bolt with washers, locknuts and made metal supports 1 1/2 in. wide by 2 in. long that fit on top of the rear bracket.
    Jun 2010
    Post
    Quote Originally Posted by rrfreng;509040[U
    ]How do you know I haven't contacted him[/U]? I Have! I was told the rear passenger footrests must be placed down on the rear supports!Then the rear brackets are solid. I NEED THEM ALL THE WAY UP!Maybe some people don't know what they are talking about!!!
    [/QUOTE] Interesting. .............. Have you contacted John?[/QUOTE]
    I don't, thats why I asked if you had You didn't say that you had contacted him, You also didn't ask any questions, just made statements of negative comments.
    arntufun
    Guest
    Is it written on the directions that the rear passenger footrests must be placed down on the rear supports ????? If not, you have a valid complaint and John should note that on the install directions so you and others will know.
    I know your frustrated, but it's not a good way to start off on this site by saying people don't know what they are talking about. Be careful of the toes you step on today, because they might be connected to the azz your kissing tomorrow when you need help with your Spyder.
    BTW, and hope you have good luck making the bracket or returning the boards for a refund.
    Aug 2010
    Newberg, Or.
    I have had several conversations with this gentleman. I have asked what I can do to help and am more than willing to take them back and give a refund. I have not heard back since then until now. I am always willing to work with those who have a problem or take them back. This is the first negative posting with almost 500 sets sold.
    Ride in comfort,
    John
    Seal FloorBoards
    Eastern North Carolina
    Quote Originally Posted by sealfloorboards View Post
    Ride in comfort,
    John
    Seal FloorBoards
    You just can't please some people.
    Maybe he'll think about it a bit and decide to come to his senses... I hope!
    John's a class-act...
    Aug 2012
    SD
    Just in case anyone cares, John, you did not offer me a refund or respond to my complaint!!!! If you say you did then YOU know what you are!
    If anyone wants to know how to stop the problem of the floorboards hitting the wings underneath, read on.
    I put 1/2 in. shims under the boards on the front supports, 3/8 may work better. You can't raise to high or you will need another shim under the brake pedal.
    Now with the supports on the back they are rock solid and also LEVEL.
    Why don't you just take it up with him in private... or do you always do your laundry out in public?
    Aug 2012
    SD
    Also would be nice if the manufacturer would fix the problems that he knows he has with these boards!!!!
    Aug 2012
    SD
    MAYBE YOU LIKE INFERIOR PRODUCTS! I DON'T!
    I can't add much here.
    I have dealt with John and he has come through on both sets of floorboards that I have on my RT's.
    Cincy is right on also!
    Jun 2012
    Nevada
    Now that's a good idea, I may go that route rather than trying to drill the original bracket.
    My wife is on the short side so the footrests have to be almost all the way up.
