Results 1 to 24 of 24
    Aug 2012
    Plattsburgh, NY
    Default Downshifting with SE5
    Does anyone manually downshift with the SE5, or do you let it downshift automatically? I have been manually downshifting because the RPMs seem to be too low.
    Invalid Emails
    May 2011
    Scottsdale, AZ
    I always downshift manually
    Thinks out loud
    Apr 2012
    Most of the time - manual.
    Arkansas
    When I slow down to the point that the rpms get to around 4,000, I downshift. Don't know if that is right or not, but that is what I do.
    At what rpms do most of you shift down at?
    Thinks out loud
    Apr 2012
    Quote Originally Posted by Dustybell View Post
    Around 4K......like to keep that clutch locked as much as possible.
    Jun 2012
    Newburgh, Indiana
    I downshift manually all the time. Sometimes the bike beats me to first gear but I usually precede it. I agree with Rattigan_Roger. Saves on brake wear.
    Aug 2012
    Plattsburgh, NY
    I've been downshifting when it drops below 4000.
    Aug 2012
    Houston, TX
    Quote Originally Posted by Rattigan_Roger View Post
    always manually.
    saves on brake pad wear.
    And coming from two wheel riding, I'm just too programmed to use engine braking to slow down to stop now.
    Palm City Florida
    Aug 2008
    Hoover, AL
    Well I guess I'm the lone stranger. I always let mine downshift itself at @2300 rpms. This is my second SE5 and I found that she gets pissed off if I downshift myself. I don't ride the brake either!
    Active Member donnellpj's Avatar
    Sykesville, MD
    Me too,...downshift manually most of the time. I do it primarily because I hate the sickening "clunk" of a automatic downshift when I goose the throttle at too low of an RPM. Ugh,...
    2014 Spyder RT Limited , OEM NA Satin Platinum
    Like most other posters above--I manually downshift pretty much all the time. Between 3500-4000 is my downshift point. About 2000 from 2nd to first.
    The above seem to give a smooth, seemless downshifts, without the dreaded "clunk".
    Akspyderlady lets her downshift by itself and she is happy with that.
    I guess there is no right or wrong--just a matter of personal preference.
    I play on both sides of this fence...
    Keeping the clutches locked-up isn't as much of an issue, since there's no drive-loads being generated...
    But I don't like paying for brake pads either!
    Jun 2010
    Austin, TX
    Lightbulb
    Manually 90% and Auto 10% (want to make sure it still does it automatically)
    4k rpms keeps your charging system charging! Remember THIS bike loves to operate in the high RPM range! Take a look at how many revs your turning @60mph and at 80mph. That is the range the engineers "designed" it to operate in.
    Nov 2010
    Tyler, Tx.
    I downshift manually on our SE5.
    Reese
    Chattanooga TN
    I nearly always downshift manually. It saves brake wear, but it also keeps the rpms up in case you have to accelerate quickly.
    When I am following a vehicle, the minute I see a brake light go on, I drop down a gear.
    Arkansas
    Oh, yeah! It looks like I'm doing good downshifting around 4,000. Always good to know I'm on the right track!
    May 2012
    Panama City, FL
    I'm like SpyderFun, 90% manual 10% auto. Dale
    Invalid Emails
    Dec 2010
    Augusta Georgia
    Always manually but let the Spyder take it home to first, just to be sure it's still working! Also it sounds terrible when it does it itself all clunky
    Jun 2010
    Rockton, IL
    I down shift manually also 90% of the time. But remember that the car behind you may not know your slowing down unless you at least pump the brake a few times while slowing down. Don't like getting rear ended
    Invalid Emails
    Jul 2011
    Yuma, Arizona
    Manually as well!
    Invalid Emails
    May 2010
    Chelan, WA .. the dry side!!
    Default Now I do....
    When I first got Ms Spyder dealer said that I never had to worry about downshifting just let the machine decide when is best .. so I did .. but after a year of following this advise I was becoming aware that the engine was sounding what I called "labored", not smooth...so thought wonder what would happen "if"....
    I am now a converted down shifter....at least 98% of the time...once in awhile the tranny will beat me to 1st....I "hear" or see RPM's reach 3900/4000 and I shift it down a gear...everything sounds better and now I feel like I reallllly am ryding/shifting Ms Spyder...just like a REAL MC rider!!!!
    Jan 2009
    austria
    I heard that they test a new software which shifts down if you need more power ..
    on a normal ryde I use the gears like here :
    http://www.spyderlovers.com/forums/m...etails&mid=276
    Aug 2012
    Harrisburg, NC
    Quote Originally Posted by Rar View Post
    I also manually downshift, coming from two wheels, it just seems natural to me. And reading other posts it seems to be the best way.
    White 2012 RT Limited
