Results 1 to 21 of 21
    Aug 2012
    Jacksonville, NC
    Default Can anyone tell me what this is?
    I was looking under the my set and it looks as if there are wires running into the seat. I have been looking in the service manual and don't see them. Can anyone tell me what this is?wire.JPG Image is upside down.
    Good question!
    That is actually hooked to a sensor that figures out if you've got a passenger onboard with you. It will then adjust the front to rear brake bias to account for the differneces in weight distribution on the bike.
    Jun 2012
    Concord, NC
    There's a switch on the seat to detect if a passenger is on your spyder. I'm not sure what for, but I think it changes the performance, or behavior with an extra body onboard.
    Jun 2012
    Concord, NC
    Good question!
    huh... Now I know exactly what it does..
    Aug 2012
    Jacksonville, NC
    is this new to the 2012's? I did not see it in the service manual. hmmmmmm
    Is this sensor only for breaks or does it have something to do with the gears as well?
    I know that my 2010 RT has it...
    It only affects how the braking forces are doled out.
    Active Member mooneych's Avatar
    Aug 2010
    South Riding, VA
    It ZAPS you if you go too fast!!
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by dschnepp View Post
    It's been on every spyder ever built.
    http://partsfinder.onlinemicrofiche....e=13&A=10&B=45
    Aug 2012
    Jacksonville, NC
    Quote Originally Posted by mooneych View Post
    I was hoping it was wires for an ejection seat if my passenger got out of hand while ryding.
    May 2012
    Jacksonville, IL
    That is exactly what I told my wife it was for.
    She said, "No it isn't."
    I said, "Just try me."
    May 2012
    Pearland (near Houston), TX, USA
    So do you have to install this sensor in your Corbin if you buy an aftermarket seat? Or do you just leave it open?
    David
    Good question, David!
    Do we have any "Corbinites" in the house tonight??
    Nov 2011
    Las Vegas, NV
    Quote Originally Posted by Spyder Monkey View Post
    David
    My Corbin has the passenger sensor on it.
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    David
    Yes. My Corbin was made with a space to install the switch. Corbin's instructions also detail the installation.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    RT-S PE#0031
    Jun 2009
    Snellville, GA USA
    Actually, it for an optional probe that when 'installed' properly measures the passengers 'pucker' and makes corresponding adjustments to the performance of the nanny...
    Information above correct. On all spyders, passenger weight sensor, had to take it off the seat and install on Corbin for 2008 model. I believe the set up on the 2010 Corbin was plug and play.
    May 2012
    Panama City, FL
    Quote Originally Posted by vrodrjs View Post
    Dale
    Feb 2012
    Portsmouth, Va.
    I was told it has to do with adjusting rear shock when passenger is onboard. it works with my Ultimate seat as well.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Grandpa Spyder View Post
    It does not adjust the rear shock. It adjusts the braking bias and other VSS parameters when carrying a passenger.
    May 2008
    Saratoga Springs, NY
    One of the "other parameters" adjusted is the sensitivity of the yaw sensor that controls the degrees of body roll allowed before the nanny kicks in when cornering, i.e. when the switch is activated by a passenger, more degrees of body roll are required to trigger the nanny.
    Quote Originally Posted by MarkLawson View Post
    I like how you think!
