Results 1 to 5 of 5
    Windsor Ontario Canada
    Cool "normal operating temperature"
    Once again, I am the newbie, but....
    When checking the oil level, instructions state that the engine must be at "normal operating temperature" before you start the engine, wait for 30 seconds, then check the oil level.
    What does this mean? The engine is 3 or 4 bars from running, or cold?
    Thanks!
    Feb 2009
    Ceresco, Michigan
    Quote Originally Posted by Windsortenor View Post
    Thanks!
    2 bars or more is 'normal'.....
    Thinks out loud
    Apr 2012
    Default OIL CHECKING
    The best/most convenient time to check is right after your ride.....no time wasted, it's at operating temp etc. Mike...
    Motorbike Professor
    Mar 2008
    Allegan, MI
    It is more than the water temperature gauge indication. It means that the metal of the engine, and the oil temperature, are within their "normal" range. As was said, the easiest way to achieve this is to ride for 5-15 minutes or more.
