Results 1 to 25 of 30
    Thinks out loud
    Apr 2012
    Default Trailer Flats - Have you had one or more?
    I'm kind of a tool box Charley and therefore am thinking about not hauling the spare to cut down weight. With all five tires being tubeless it kind of makes sense, I think. But before I leave it home for the first time it would help to know what others have experienced.
    Jer
    Jun 2010
    Las Vegas
    I have Ride-on in my trailer tires and I do not carry a spare.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Invalid Emails
    Jun 2010
    Jackson, Michigan
    Same as Ann.......
    May 2012
    Greenfield, WI
    If it was me, I could ride 100,000 miles with the spare along and never need it. As soon as I would leave the house without it, I would get a flat about 10 miles out (just so riding back on the flat would not be an option)
    Jun 2010
    Ferndale, Washington
    I have Ride-On in the RT-622 tires and also carry a spare tire&wheel. With this combination I hope I never have a flat on the road.
    Thinks out loud
    Apr 2012
    Quote Originally Posted by can-am sam View Post
    You must have been an Eagle Scout
    Jun 2010
    Austin, TX
    Post
    Quote Originally Posted by Jerbear View Post
    Jer
    Have you thought of carrying a tire repair kit with pneumatic pump? Its lighter than a spare tire and cheaper too. I think Lamont had a tire blow on his 622 due to a seized bearing. I have Ride-On in my bike but not trailer.....yet.
    Aug 2010
    Riverside, California
    I have Ride-On in the RT tires and the 622 trailer tires, carry a spare, Slime w/compressor and AAA card. I should be covered.
    Thinks out loud
    Apr 2012
    Quote Originally Posted by stevedfive View Post
    I have Ride-On in the RT-622 trailer tires, carry a spare, Slime w/compressor and AAA card. I should be covered.
    Aug 2010
    OH! And a trunk monkey.
    Jan 2012
    Pelham NH
    I love the trunk monkey. LOL
    Jun 2010
    Henry, VA
    I also carry a spare, have ride-on in all tires, have an air compressor and have not had any tire problems in 17,000 miles. I hope that I have not jinxed myself by being proud of being as prepared as possible.
    Rudy
    Thinks out loud
    Apr 2012
    Quote Originally Posted by Cal777 View Post
    Rudy
    I hope not too
    Aug 2010
    Oh , now we are all doomed!
    May 2011
    Round Rock, TX
    I carry plugs and a compressor.
    Murphy's Law says that if you carry a spare for the trailer you'll have a flat on the Spyder ... and vice versa. And we all know Murphy was an optimist!!
    thehawk
    In theory, there is no difference between theory and practice ... in practice, however, that's just a theory.
    Thinks out loud
    Apr 2012
    Quote Originally Posted by thehawk View Post
    Murphy's Law says that if you carry a spare for the trail you'll have a flat on the Spyder ... and vice versa. And we all know Murphy was an optimist!!
    thehawk
    I know Murphy - just wish he didn't know me
    Invalid Emails
    May 2012
    Nicholasville, Kentucky
    Wally World carries a selection of Slime repair kits. Included is a pump, and sealant. From $20-$60 depending on pump sizes. I also carry a plug kit ($5.00 +/-) for a roadside repair. That will repair any tires on bike and trailer. Most local Wal Mart stores have these, as well as auto parts, and other retailers. A good investment if you have a little space to carry these.
    http://www.walmart.com/search/search...h_constraint=0
    Jun 2010
    Austin, TX
    Exclamation Pump Info
    As an FYI....NEVER use the accessory plug in the rear trunk to power your air pump. It is not rated to handle the amperage your air pump uses...you will blow the fuse for the accessory plug.
    Jun 2010
    Henry, VA
    I have used the rear plug to run my compressor many times with no problem blowing the fuse.
    Rudy
    Jun 2010
    Austin, TX
    Post Compressor Amps vs Accessory Amps
    Rudy
    Rudy, I think you have been lucky....so far. Most Air pumps are rated for more than 3-amps (see your compressor label). This means IF you need more than 3-amps the compressor WILL call for it and the accessory fuse WILL fail - as designed.
    See your Owners Manual pg 49 for the following:
    Using the 12 V Power Outlet
    A 12 V power outlet is available on thevehicle. It is located in the top storagecompartment.
    A 12-volt electric appliance may beconnected to the jack connector. Electric current is supplied all the time.
    NOTICE
    The 12-volt power outletis not designed to supply current ofmore than 3 amperes.
    NOTE: Leaving an appliance con-nected while the engine is not runningwill gradually discharge the battery.
    Apr 2012
    USA Andrews, TX
    Default 12v Outlet
    I've always used the Battery tender plug it's got a 10 amp fuse.
    J. D.
    Jun 2010
    Austin, TX
    Post
    Quote Originally Posted by 20Limited12 View Post
    J. D.
    I too use a battery tender. The "battery tenders", if installed correctly, are wired directly to the battery terminals which means the fail-safe is the "in-line fuse" installed in the tender to battery lead. This bypasses all the fuses the bike has. The in-line fuse should be rated less than the pump (this prevents the pump from being burned out due to excessive amps and associated heat) which saves the pump.
    Invalid Emails
    Jun 2010
    new braunfels, texas
    Wow from carrying a spare tire , to fuse and air pump amazing how quick a post can go south lol, I think a spre is good insurance that is why they put them in cars,ect oh well
    Each to their own thoughts
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    Don't put Slime in the tires. It corrodes aluminum rims. I had RideOn in my RT but then it started balling up inside the tire and causing vibration issues. My mechanic got upset at me for using it too. Don't want to piss off your mechanic. No no no no no
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
    Thinks out loud
    Apr 2012
    Quote Originally Posted by texasride View Post
    "amazing how quick a post can go south" True.
    But, sometimes if you just let the horse go, you discover new ground
