RT Sway Bar
I am replacing the sway bar on my RT. Does anyone know if the front trunk can be loosened from underneath so that the trunk can be lifted. I am pretty sure that on the RS you can. This means that the new bar can be fitted by accessing all of the bolts from underneath and no body panels have to be removed (apart from the skidpan). Has anyone removed the sway bar on an RT, any advice? Thanks, Daryl
