Trailer laws?
I will be pulling a trailer on my spyder soon. Can some one tell me what the laws are regarding license plates? I see some with and some without.
You should contact your DMV. I'm sure all trailers must be licensed, but not all states may require an actual license plate.
Dave, I would think that the RT trailer would fall in the 3rd category of less than 2000 pounds and therefore wouldn't require a license in KS
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Trailer laws vary from state to state...and trailer to trailer. In Michigan, trailers under 2,500 pounds, are registered and plated, but not titled. Larger trailers are tiltled. We have permanent plates, with a one-time fee. Check your DMV. Kansas law exempts trailers from registration if the total weight of the trailer and load being carried does not exceed 2,000 pounds.
Trailer license
In Minnesota a small sticker is attached to the trailer tongue. Therefore there will not be a plate. This is for small utility trailers with a 3000 lb load limit.
I would expect rules or reciprocity to be in effect between states on this subject. My state you don't have to have a license for trailers under 3000 lbs that are not used for commerce, though if you have extra money sitting around that you have no good idea of what to do with it, the state offers an optional plate for your trailer at a price.
You have to register and license-plate any trailer in Illinois...
We are dying in debt here... so they license and register everything here.
Pennsylvania
Requires title and plate... $6.00 a year, but they WILL allow you the "luxury" of pre-paying 5 years at a time for $30.00... What a deal!
It is my understanding that even if the State you are aresident of does not require a plate once you leave your home State you arerequired to comply to the laws for that State or States you will be travelingthrough.
RT-S PE# 536
It is my understanding that even if the State you are a resident of does not require a plate once you leave your home State you are required to comply to the laws for that State or States you will be traveling through.
This doesn't make much sense. If I travel to a state that requires a plate, I'd have to stop and buy one? Or if I have plates on my trailer, would I have to take them off if I went into a state that doesn't require plates? I believe you only have to comply with your own states requirements.
Jay on Omega Bay Texas
Spyder RT-S PE# 536
But if your State doesn't require a plate it wouldn't hurt to carry that documentation so as to head off a loud discussion with a LEO in another State...
I live on the border of Illinois and Wisconsin.
Wisconsin doesn't require plates for small trailers (basically anything short of a semi-trailer)... Illinois does require plates.
I see people from Wisconsin all the time pulling trailers of all types without plates when in Illinois and they never seem to be pulled-over for it.
My observation is that if Wisconsin doesn't require plates, then Illinois abides by that for those traveling through Illinois.
It is easy enough just to check the laws though...
While that does apply to equipment like lights, brakes, or reflectors, and to things like earphones and speed limits, it usually does not apply to title and registration requirements.
TN doesn't require to register the trailer due to the weight, but they encourage you to do sign for the tags in case a rider goes thru a state that requires tags even if you are not a resident. One of those deals where states don't see eye-to-eye At least the renewal fee for it is $12.00 a year.
SpyderLovers Founder
Here in TN I don't need a plate on any of my trailers. If I plan to leave the state then I need to buy one in TN to comply with other state laws. I have traveled without a plate on in other states but I like living on the edge...well sometimes
I guess that I need to dig through the rules a bit deeper. I thought that reciprocity was 100% across all State lines...
LEGALITIES
I am a retired LEO and if you are legal in your state you are legal in all 50 states.....but and there is allways a but....the laws in you're State are not necessarily known by the LEO of the State you just got stopped in.....in fact the LEO probably is not familar with you're States laws unless it borders it.......so there may be a lengthy delay till everything is figured out.....Carrying a photo-copy of some strange State Statute you plan to hang you're hat on is not a bad idea......IMHO...Mike.....Just a heads up
