11-04-2011, 11:22 PM
#101
Mod Monster
Here's the RT622 work so far. More pics to follow.
MODS
1. Interior light halo ring.
2. Purple side fire LED external rings on front and back lid.
3. Backup lights- LED
COMING
1. GloRyders on wheels.
2. Maybe a little more
I'll also post, later, a how to.
Sent from my iPhone7 using Tapatalk
____________________________
Phil - Tyler Texas
2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
11-05-2011, 08:05 AM
#102
MOgang Member & Monster Member
Nice. No fumbling around in the dark there!
11-05-2011, 09:49 PM
#103
Mod Monster
No dark left in which to fumble my friend
Phil - Tyler Texas
11-05-2011, 10:28 PM
#104
Mod Monster
GloRyders on the TR622 Trailer
I can't say enough how much I like working with Kurt at GloRyders. AND... I need to say that this mod is NOT a GloRyder sanctioned mod. It is 100% DIY. WARNING- if you do this mod, there is the chance that the light can spontaniously fly off! But read on....
No standard GloRyder lock piece will work on the 622 trailer. The distance from the wheel to the dust cap is very shallow. About .144". Kurt and I had several email exchanges and the bottom line is that it doesn't look like a piece can be made to act as a lock for the main, chrome, GloRyder body.
It SO HAPPENS that the 'Y' plastic cap is within .1" of being the same size as the GloRyder body. So.... here we go....- Remove the plastic cap. It takes a a bit of work because it is snug.
- Center the GloRyder body on the cap.
- Drill 2 holes the same size at the holes in the GloRyder body.
- insert 2 screws
- Put a little LocTite on the threads, lock washers, and nuts
- Insert all of the light guts and the cap and test.
- Here you can see just how shallow the space is from the wheel to the dust cap. But the screws, being at the sides, clear just fine.
- Here's what it looks like after it is press fit back in place.
- Start to finish was about 10 minutes per wheel. I got it up to 70 on a road near the house and then pulled into a parkinglot. 100% all fine! I then did 20 miles and there was no change and it was fine. I went to Sams, shopped, hit rough spots, trying to shake it around, and it never moved. NOT to say that it will never move
- I AM going to make ONE addition to this. I'm going to add a large strip of industrial Velcro between the plastic cap and the dust cup. It will add another level of confidence.
Again- this is not rock solid so if you want to do it.... well you get the idea. But it really does look cool with the GloRyders with my custom cut dove logo on both the bike and the trailer!!
Phil - Tyler Texas
11-05-2011, 10:48 PM
#105
SpyderLovers Founder
11-05-2011, 11:29 PM
#106
Mod Monster
Lights for the RT622 Trailer
I really need counseling I guess. I had so much fun adding loads of lights to the Spyder, that I HAD to do something to the trailer. This is the 2011 trailer which uses only 4 wires:A= Ground
B= Tail Lights (both)
H= RH Brake & Turn
J= LH Brake & Turn Pretty simple actually. I tapped the Ground and Tail Light lines inside the back of the trailer as a source of +12vdc and -12vdc. I got a 4 zone remote light module and mounted it in a vacant spot in the back of the trailer.
A little velcro holds it nicely. As you can see, it's super simple to wire up. Here's how I wired itZONE1= Interior halo of super bright white LEDs
ZONE3= LED Backup Lights
ZONE4= Purple LED side throw and general PURPLE accent lights This remote has the multiple dimmer/flasher/breathe modes. There WILL come a day when I'll swap it for the new Black Magic remote.
Installing the LED strips is really straight forward. Getting all of the wires back to a 'central' place is a bit of the head scratcher, but I got it. For the front hatch, there was this solution...
Black clothgaffer tape works VERY well. I may end up getting some extra wide black plastic '33' tape to replace the gaffer tape. The black wire that is tiewrapped to the hinges is called Rotor Wire. It is #22 3 conductor that is very flexible and the coating does a good protection job.
Here's what the rat's nest looked like before I cleaned it up and put the plastic shroud back in place.
The blue shroud is for the new backup lights I added. Funny thing... BRP uses the same housing as they do on the bike. They and all the parts are made in Italy by CEV. On the bike, the backup light holders actually hold a light. On the trailer, the same holder is filled with some black stuff, capped with a silver reflecter, wires cut off and duh. They plug a hole. I TRIED getting the lamp holders from CEV, but no luck. Thanks to a brainstormng session with Len @ Cowtown, I got GM lamp sockets, cut off the 'ears', wired them, and used silicon seal to hold them snug in the holes! Thanks Len! Here's the results....
For now, when I backup at night, I'll use the remote to power up the #3 Zone and whaaaaa la.
One task was rather tedious. The side throw LEDs only came in 18" lengths. The longest I needed, to do a ring around the hatch, was 96". Break out the soldering iron and very short wire, heat shrink, torch and the magnifying glass. Not sure how, but all of the work to extend the light sets worked!
All in all, a fun mod. The total current draw of all LEDs lit is less than 2 amps! Basically no drain on the circuit. I'll have a few 'portrate shots' showing all of the lights soon.
Phil - Tyler Texas
11-05-2011, 11:46 PM
#107
Mod Monster
Originally Posted by Lamonster
Great mods Bro.
I'm thinking a rare earth magnet, epoxy it to the inside of the cap. The trick would be getting the right thickness. Or you could pull the axle cap and drill a hole dead center and run the bolt through the cap with a nut and have it just long enough to go through the Glowryder and bolt up.
Hummmm.... rare earth circular magnet.... Edmond Scientific here I come!
Kurt & I talked about drilling the cap, bolt, etc. May still do that. There might be a clearance issue with the electronics pack when the pack batteries are in. They come pretty close to the bottom of the chrome housing. Worth another look. Thanks Boss!
UPDATE--- Magnets ordered!!!!
Phil - Tyler Texas
11-06-2011, 03:30 PM
#108
I've been wanting to do the GloRyder mod on the trailer, but gave up on the idea when I found the clearance wouldn't work. Glad you pursued it anyway. Am anxious to get a final assessment on how well it holds together.
Question... How did you get the plastic cap off? Is there a trick to it or did you just pry until it popped out?
Oh, and want pics of the exterior lights at night, with the lids closed. How well do they show?
11-06-2011, 03:58 PM
#109
Mod Monster
Mark- I took it to 93mph today for 30sec with the remainder of 10min at 75, and they didn't budge. When I got back, I pulled them off and added the Velcro I talked about. It's the WIDE variety that is REALLY strong. I really like Lamont's thought about the magnets so I ordered 4 that are 1/8" x 1.75" I'll epoxy 1 to the plastic cap and see how well ot holds, if not, I'll add the second to each side.
GETTING THE CAPS OFF- Just pry with a vert small screwdriver. They ARE hard to remove, but they will come off.
PICS---- Heeeere ya go, in the dark garage....
I'm thinking of adding chrome accent strips in a few places, to reflect the trailer lights. I'm a fan of purple, but black doesn't show it much of course. And I kinda like it being understated. They REALLY show nicely on the CanAm stickers, so that may happen soon.
Phil - Tyler Texas
11-06-2011, 07:58 PM
#110
Looking good my fellow light addict.
11-06-2011, 08:55 PM
#111
Mod Monster
Phil - Tyler Texas
11-10-2011, 06:51 PM
#112
Mod Monster
Great mods Bro.
REFERENCE--- http://www.spyderlovers.com/forums/s...l=1#post388323
We HAVE Magnets!!! They are rare earth neodymium magnets.
These puppies are REALLY strong!! I bought 4 2" and 4 1 1/2". Those white things are spacers. We accidentally got two stuck together and it took 10 minutes to slide them apart.
I think I'll use the smaller one and add a sheet of metal between the plastic cap and the magnet. I'm afraid that epoxying straight to the plastic may cause the plastic to break when the magnet is pulled away from the dust cap. We'll see...
How is neodymium pronounced?
From a dictionary: [nē"ōdim'ēum]
The only real trick to pronouncing it correctly is to treat the 'y' as an 'i'. It is pronounced as if it were spelled "neodimium" or "neo-DIM-eeum".
Phil - Tyler Texas
11-10-2011, 07:48 PM
#113
11-13-2011, 11:14 AM
#114
If it took you 10 minutes to slide one magnet off the other, then they should do the trick for you. Let us know how it turns out. Hopefully your Spyder will not be too attracted to other vehicles now though.
11-18-2011, 11:29 AM
#115
Will you use the same two screws to hold the metal sheet on that you used to attach the GloRyder base to the plastic cap? Is there a chance that the strong magnetic field might interfere with the switches on the circuit board? Have you done it yet???
11-18-2011, 12:17 PM
#116
Mod Monster
1. Yes, I'll use the screws to hold the metal in place. That way it will assist in distributing the pull load. I'm thinking very thin tin.
2. Magnetic interference?- Possible but I doubt it. The only item would be the motion sensor and that will depend on what is in the device. IF it's mercury, it's possible the magnet can mess that up.
3. Haven't tried it yet beyond a simple trial. I ended up having to order a THINNER magnet. The 1/8" is still too thick. I did some customization (aka grinding) to the 1/8" to fit it between the screws and learned that it was too thick. So... more magnets, 1/16", on order . They will STILL be strong enough, believe me. IF there is room, I may use both the magnet and the Velcro.
FYI---- The super duty Velcro that I currently have on there is really strong. It has pretty much full contact with both pieces. When I pop on the Gloryder/cap, I then twist it back and forth a little bit to get more of the hooks to engage the loops. It takes a pretty solid pull to get it to come off.
Phil - Tyler Texas
11-18-2011, 11:46 PM
#117
Since wheel bearing hubs can get warm, did you use any special adhesive to make sure the Velcro stays in place? Thinking real hard at doing this & want to get all the info I can before placing the order.
Also, tell me about the design on the GloRyder caps. Custom?
11-19-2011, 01:15 AM
#118
Mod Monster
Had not considered the heat! Good catch! Hummmmm. Lamont suggested pulling the bearing caps, drill a hole dead center, put a bolt through the back, use that as the anchor. Remains to be seen if they'll stay put. I plan on putting 300 miles on them this weekend to see how they do.
Design- yup, custom. Part of our company logo! Same on the front.
Phil - Tyler Texas
11-25-2011, 09:22 PM
#119
Mod Monster
12-09-2011, 07:48 PM
#120
12-09-2011, 11:04 PM
#121
Mod Monster
Originally Posted by SpydherLuv
Hey Phil, I've been following your mods for awhile and wanted to be sure to tell you how awesome your write-ups are - really great job! I'm interested in a few of your mods and have some questions that either you, or others, can answer. - Where did you get your voltage gauge? And do you have the steps on how to install it?
- Did you use a fuse box when you installed the dash 12v outlet?
- Do you know whether installing the HID lights eliminates the 'flickering' that is common in the OEM headlights?
- What power line did you tie the glove box LED strip into?
Thanks!
Anita
Hey Anita!!!
Thanks so much for the comments!
Unfortunately I'll need to REMEMBER to answer on Monday from a real computer rather than this iPhone thing Because I need to look up a few things since my old brain has already forgotten how i did some things!
I CAN tell you that knowing I was going to get addicted to this mod thing, the first thing I did was to add a separate fuse block in the front of the bike, to which almost everything is tied. Including the glovebox light. Actually the glovebox light & under dash light go through an LED dimmer. That's one of the blue knobs you see in the glovebox.
I have a master switch for all of it. The tricker bit is that the switch drives a relay that controls the power to the extra fuse block. It's much cleaner..... And confusing
On the 12v accessory outlet, I can't remember Funny I was thinking about this yesterday!
On the HID vs flicker question.... No clue. Sorry.
I'll try to catch the rest of it on a REAL computer Monday.
Phil - Tyler Texas
12-12-2011, 05:35 PM
#122
Mod Monster
Thanks!
Anita
Anita (from my 'real' computer)----
From- AEM Only- http://www.aemonly.com/digital-gauge...gauge-258.html Installation is VERY VERY simple even if you only know a small amount about 12vdc electrical. When you remove the stock gauge, you'll pull out the plug that has all of the wires attached to it. Use a voltmeter (get a cheap one from Radio Shack if you like) and find out which of the wires is +12vdc and which is -12vdc (also called the ground). The meter will have (as I remember) 3 wires- a red, black and blue. The instruction sheet that comes with the meter will help here. You hook the red wire to the +12vdc and the black to the -12vdc. That's pretty much it! - Did you use a fuse box when you installed the dash 12v outlet? As I said in my previous post, the FIRST thing I did was to add an extra fuse block in the front of the bike. It added about 8 fuse positions. I'm PRETTY sure I added the 12v accessory outlet to that fuse block and put in a 10amp fuse. That means that it, along with everything else I've added, goes off with the push of one switch. As I said, doing this through a relay is the best thing, but it is more tricky.
- Do you know whether installing the HID lights eliminates the 'flickering' that is common in the OEM headlights? I never had flicker in my OEM halogen lights so I can't comment.
- What power line did you tie the glove box LED strip into? Through a dimmer into the extra fuse block I added. A COMMON fear with LEDs is that you'll unbalance or blow something. That is 'possible' but it is remote. I now have about 2000 LEDs on different parts of the bike and trailer with no issues. Ok... I blew a 3amp fuse and replaced it with a 5amp. But... all is good and everything plays nice together. My advice is try adding whatever you are going to do with LEDs, but TEST it first on the bike. Get alligator clip wires and try your ideas first, THEN do things more permanent.
HAPPY LIGHTING!!
Phil - Tyler Texas
12-14-2011, 05:31 PM
#123
12-14-2011, 05:46 PM
#124
Phil---Really nice and impressive! Enjoyed seeing some of your work in Woodville.
Glynnk
12-25-2011, 07:18 PM
#125
Hey Phil got a question for you.
Got a Sony Bluetooth adapter like you show in the picture.
A pair of Sena SMH10 bluetooth headsets.
Zumo 550 GPS.
Iphone
When I pair the Iphone with sena headset, then blue tooth sony adapter to the Sena headset.
I can listen to the Iphone music, when the phone rings I can answer the phone and it will return to the Iphone music.
But when I have the sony adapter hooked up to bluetooth on the radio and I get a phone call , I can answer the phone but it will not return to the music.
Friend has a Clear Sounds Bluetooth adapter that will.
Got any ideas what might be happening that it will not return to the music on the Sony
Thanks.
