Registered User
Blazing Member
Great pics !! You make it look so easy .
All right! Your first mod and you haven't even been able to take to the road yet.
Purchasing the Spyder is a down payment for the mods...
Registered User
Just be aware that is probably the cheapest mod you are ever going to be able to do!
It does make the front wheels look better though, at least in my humble opinion.
Sweetness!! This was one of our first mods too other than the 12v socket and fog lights we ordered when we put our deposit in.
HAPPY MODDING!!!!
I like the look too! But... I got mine and the damn adhesive never stuck. So I never got them on. I still have them so I am curious as to what else I can do to make them stick?
Mole
What about this
Mole
Did you rub the break with alcohol? What about contact cement? Just a thought, I used that on my first jet ski to hold down the hydroturf and it held it down very well.
Registered User
Mole
Hi, thanks for the note.
I did use a little heat to install them. Basically I just put a halogen light close to them while I installed them, and the heat from the bulb (I'm hoping) helped to get the adhesive working good. I then held them in place for 30secords of so, and pressed in hard on them.
Perhaps something like plastic-glue (http://solutions.3m.com/wps/portal/3...stic-Adhesive/) would work for you since the self adhesive is likely worn or not functional for you now. Products like this, or similar, are flexible and easy to install. I would wonder about CA types glues, unless it has a low viscosity. The really runny glues may not work well and become brittle in colder temps, as it goes on very thin. Just my thoughts.
In any case, the important first step is to thoroughly clean the calipers with alcohol or a good cleaner that takes grease and oils off its' surface.
Also, watch out, don't let glue drop onto your rims.
Hope that helps.
Cheers.
Removing any grease or dust from the surface plus heat should get you good adhesion.
I painted the calipers red before installing the trim pieces. No problem with them sticking to the new paint finish, however using GE silicone rubber to "glue" the pieces down would work if anyone has problems installing them.
I had a set not sticking. I used Silicone glue on them.
2010 RTS-SE, Orbital Blue
spyder caliper trim
I was going to get a set for my RT, but when I talked to the dealer he told me that he had 3 sets come loose. The caliper is cast(not smooth)which does not let the glue stick well, in addition the heat build up in the caliper causes the glue to lose adhesion properties.Needless to say, I left without purchasing that accessory.
Looks great!! Can't wait to see more pix.
Very Helpful Member
Originally Posted by NancysToy
What's with the tariff costs? I thought NAFTA provides for free trade for personal items. I never paid duty on anything I got from Canada.
Afta NAFTA, the shafta....
Those were someone's words of wisdom written in a restroom stall at my workplace.
Former Happy Spyder Owner
Just decided it was time to move onto other things.
And rightly so!
Registered User
Originally Posted by Donzo
You inspired me! I just ordered the trim on ebay for $15 delivered..cheap indeed!
That's great!! Be sure to post a couple pictures when you get them installed.
If you have any questions on the installation, post 'em here!
Cheers, and have fun!
I was tracking the Fedex shipment from Canada - it came up delayed at the Toronto border for days. Then a Fedex broker called and told me that anything over $200. has to be declared and has tarrif and taxes applied
I talked to Ken at Vertica and he said most slip through without the Tarrif being charged - I'm just lucky I guess..............
Took over 6 weeks to get the product and $200.+ in shipping and tarrif/tax cost.
Originally Posted by SpyderWolf
Do you have pictures posted of what you did with the Vertica Trikes stuff on your Spyder?
I will post some pics of my mods in another thread - it is never ending!
Registered User
Cool, sounds good.
Cheers and good luck!
Question: Do these caliper accents fit on the RTs also??
