Dual Exhaust and ?
I've ordered a Two Brothers Dual Exhaust with P1X powertips for my RSS. What else do I need to add along with the exhaust? I've read several threads regarding a Juice Box...do I need it? Also, when is the best time to install the exhaust (i.e., mileage)? My new Spyder has just over 100 miles on it.
Just installing the exhaust you should be fine. The ECM has enough flexibility to adjust for that. The main thing is when you install the new exhaust you want to let the Spyder idle for 15 minutes to give the ECM enough time to remap the fuel program.
If you start adding other things, like an air intake system, then you may run into Juice Box territory. I am currently running a K&N air filter in the stock air box with the Hindle exhaust. I added the Evoluzione O2 modifier to the mix and my Spyder runs great with that set up.
You can add the new pipe anytime you are ready.
Evoluzione O2 modifier made a big difference on mine when I added the Two Bros dual setup.
Thanks! Is the O2 modifier easy to install?
YES....I suggest not leaving the original 02 sensor in the exhaust, use the fill plug provided.
Okay...so I decided to get the O2 modifier...can you recommend a website to buy it from?
http://www.evoluzione.net/evo-cycle-can-am.htm
If Nicko doesn't buy it, you can't beat this deal: http://www.spyderlovers.com/forums/s...ad.php?t=28675
Thanks everyone for the help!!!
I bought and installed a Two Brothers Dual Exhaust "Black Series" with a Evoluzione O2 Modifier. I also added the P1X powertips to bring the decibels down a notch (don't want to set off all the car alarms as I leave the neighborhood). It sounds amazing and looks GREAT!
Im glad it worked for you i have a 08gs and tb duals with knfilter and no luck with jb and 02mod ended up going with pcv and runs like a raped ape no more poping on decel and hesitation is gone.
Glad to hear you got things sorted out to your liking.
Does the 02 mod work ok with 2011 on the website it says it's for 08 and 09. I put a Two Brothers Dual Exhaust on my wife's RS-S and it doesn't idle very smooth now. I want to add the tips but haven't yet.
Earplugs. Seriously... Just inject epoxy in your ear canals....You're going to need it.
That dual setup sounds awesome at idle and is stupid loud at speed... But sounds awesome... like a hot rod.
