55w 6ks with that blue tint is going to be sick looking on your spyder man.
You definately have to take pics when you get that bad boy set up!
![Quote](images/misc/quote_icon.png) Originally Posted by DaBusses
I can't see where a melt down is likely. I just sold my Harley V Rod that I modded with 55W 6K HID's. (DDM Tuning w/lifetime warranty and less than $50 for the whole setup) The V-Rod uses two lamps in one headlight enclosure. I didn't notice any additional heat over stock halogen lamps. And on top of that, I actually wired the lights so both Hi/Lo beams where lit when Hi beam was selected. Awesome amount of light on Hi beam at night, very visable and safe during the day. I have actually had more cagers, flash my stock RT-S lights at night than I did on the Harley.
My ![spyder](images/smilies/spyder.gif) RT-S has the shades for low beam and projector looking lenses and I'm not sure how the HID's would perform. But as you say, for the low cost, I made just go ahead and order them.
Sorry for the long novel.
Thanks for that additional info as well. The link I posted somewhere above has the RT with 100 watt HID installed in a video.
A Guinea Pig, is a Guinea Pig. I will let my order stand and test the results once I get everything installed. If there is something I don't like, or the few cars I do see on the road are constantly flashing me, then we can start a whole new discussion on that.
I was able to get everything I mentioned for $125, as the slim ballasts were more expensive, the 55 watt bulbs cost more, and the 3,000K bulbs cost a little more as well.
![Quote](images/misc/quote_icon.png) Originally Posted by Motavar
The bulbs were cheap enough that I purchased a set of 3k fogs to test out and ran them for awhile. Unfortunately with the side markers being orange, the fogs being yellow and the headlights being white it didn't look right on MY spyder. On yours I think it will make a good combo because of your color scheme/graphix package.
I was going with yellows so other drivers would notice me more but it seems like the yellows were not standing out much during the day. I switched back to 5ks in the fogs and put white leds in the side markers to match them all up.
The Yellows were definately cool to see in action.
Thanks, I will definitely take pics and a video of before and after. I also chose the yellow because I figured they are the real fog light color, and would go good with my Spyder lighting. The amber fog light rings should work well with them, at least I am hoping.
Yes the 6000k up and down looked really good
And 55w hid should be just matter being brighter and not being a more burden on spyders electrical system.
![](signaturepics/sigpic2825_4.gif) 6 states down 42 states to go ![Spyder2](images/smilies/spyder2.gif)
I'm sure aka1004, wolf, and others already know but I'll throw this out there:
Over time the HIDs will slightly change color to a higher color spectrum (K value). Did you ever notice that some older BMWs or Acuras have a blue'er or purple color headlights from when they first came out? After a few years the color shifts a bit.
You may see people on the road with one white light and one blue/purple light because they may have replaced one bulb and the new bulb doesn't match the color shifted bulb. Phillips offers a 5k+ D2S replacement bulb to help match aged bulbs in cars and they offer a stock 4300 bulb. A lot of people don't know this when replacing bulbs and end up with the 4300 which looks a lot different from the other bulb that has been in there awhile.
Just throwing this out there for additional reference:
When installing the HID bulb the bar should face down.
Unfortunately because the way some bulbs are made you are stuck with the bar being up. The HID will still fire okay but you may be subject to a shadow being cast out in the light ahead of you.
You see this more often in cars that have reflector headlights instead of ones with a lens.
Spyderwolf
Here's the ones I purchased from esi; they are 35W, 8000K, white:
http://www.dhgate.com/h7-8000k-3800-...p%20h7%208000k
The price I paid doesn't bother me. I was wondering if there was a difference and Justin answered that.
This is all new to me, so thanks for the additional information as well as the installation tips.
![Quote](images/misc/quote_icon.png) Originally Posted by wyliec
As long as they work. It seems to be hit and miss with HID's. You would notice some difference going to 5000k or 4300k. I personally don't care for the 8000k. They look good but the lower k's perform better.
![Quote](images/misc/quote_icon.png) Originally Posted by Mr Orange
Are you on that forum?
Lately I have been having some weird VSS issues, high RPMs on start, and failure to starts. Finally figured it out and as it turns out... it matches exactly what Leo was explaining on another thread:
http://www.spyderlovers.com/forums/s...558#post275558
When my HID fogs are on and I attempt to start the spyder I get warning lights like crazy.
I definately confirmed today that the HIDs using the stock fog wiring causes an issue with the VSS/computer. While driving I turned the fogs on and the computer freaked out and shutdown. (was fun going 75 in the middle lane of the 3 lane highway in rush hour. Luckily I was able to get to the side of the road in time).
So the firing of the HID on the fog wiring must dip the power just enough for the VSS to freak.
* I believe the solution is to get a HID relay harness. Off to ebay I go
* I believe the solution is to get a HID relay harness. Off to ebay I go ![Smile](images/smilies/smile.png)
Now you know why BRP specifies that you install a separate auxiliary harness when you run both HID headlights and their fog lights...and they haven't even ventured into HID fogs.
![Quote](images/misc/quote_icon.png) Originally Posted by Justin
I run the 3000k fogs in one of my Phantoms.
Thanks for the pictures Justin! I think the 3,000Ks will work very well on my Spyder after seeing these.
The stock harness from BRP is supposed to be $99. I believe my Spyder already has this, as the dealer that did the foglight install said I had to have this add-on harness in order for them to work. Of course, I found out later that harness is only needed for the HID set up. So, I am hoping that since I already have it everything will be good to go.
Justin, have you had any problems running your fogs on HID?
Relay HID harness on ebay ranges from $7-$16
It's basically a 40 amp Relay, a few wires, and an inline 25 - 30 amp fuse.
When the lights kick on, it signals the 40amp relay to pull power directly from the battery instead of the fog light wires for power to fire the HID.
You can build your own harness but the ones off ebay are nice because they are plug-n-play. They have all the waterproof connectors for attaching to the lights/ballasts.
-Mot
![Quote](images/misc/quote_icon.png) Originally Posted by IWN2RYD
![don't know](images/smilies/shrug.gif) On the BRP site the RS HID kit is now $899 and the RT is $1000. Did they pull these? Or are you speaking on just the fog and they are not offering both? Thanks Scotty... ![2thumbs](images/smilies/a18.gif)
BRP only offers HID headlights, so far there has not been a fog light offering from them.
-Mot
I hope this works for you. Keep us posted on your progress.
Order placed.
We will find out in 3-4 days (shipping time)
When all is said and done we can write a sticky on the mod forum for HID stuff.
for my lights to not cause any problems, I ended using different bulbs... and not letting the ballasts and wires not touch any part of the frame... too much electrical interference from the ballasts was my guess... but the Spyder works fine now... Good Luck!!!
![Quote](images/misc/quote_icon.png) Originally Posted by SpyderWolf
I've had no issues at all. I can start the bike with all on.
Justin,
How do they perform better? Less problems? Last longer?
Justin,
brighter
![Quote](images/misc/quote_icon.png) Originally Posted by leo76dragon
for my lights to not cause any problems, I ended using different bulbs... and not letting the ballasts and wires not touch any part of the frame... too much electrical interference from the ballasts was my guess... but the Spyder works fine now... Good Luck!!! ![thumbup](images/smilies/thumbup.gif)
Thanks for the update Leo.
Thanks for the additional info Justin. I appreciate it as well.
Okay wolf check this one out..
So I ordered a few replacement relays the other day that just happened to show up today. ![Smile](images/smilies/smile.png)
My main relay #1 on the 09 GS was a 30/20. I popped in a 50/30 and my startup issues and VSS issues completely went away. I went out in the cold frozen grass in my front yard and spun the byke around like you wouldn't believe popping the vss light up the wazzoo and instead of the spyder shutting down it was fine.
So my question is.. on the 09's up: should the main relay be a 30/20, 35/20, or a 50/30?
I went over the relay thread on here but **** just confused me more.
Update: 9:00 pm est:
I put the 35/20a in and was able to get a VSS fault when starting. The 50/30 still no issues.
I'm guessing it's safe to keep the 50 in there as the whole circuit should be protected by the fuse in the back box. I will still assume this issue will go away when I put the HID relay harness into play.
...but..this makes me wonder if the stock relay is too low for continuous VSS detection. For example: I know once before when I went through 6 inches of snow in my driveway to get into my garage the VSS kicked in like crazy and shut the whole spyder down. Now I'm wondering if the relay just can't handle the switching required during long periods of VSS. Could the higher relay be more reliable under continuous load over the smaller 30amp one and be a better choice?
