Spyders in the smokies pictures
Great Pics. Thanks for sharing. What was the average speed of spyders doing the dragon?
Originally Posted by altonk
.......when you turn in leave your foot on the brake enough to keep the brake light switch engaged , a kinda imaginary trail braking thing it seems nanny is hesitant to tap a brake for you if you already are braking
I discovered that technique a while back, but didn't really analyze the whys or wherefores. I never thought I was actually trail braking with enough braking force to do much good (although the Spyder seems to like it along with a little throttle at the same time). Thanks for an explanation that makes some sense.
Great pictures ....
I think the wife and I will try to make it next year!
I found it hard to get my foot on the brake when doing a left twisty because I'm hanging off the other side like a monkey !
Those are some good pictures, thanks for sharing them.
It was a great time running The Dragon with you as well. From the looks of the photos of us on US129 Photos, I need some suspension assistance as I have a serious rolling compression issue on the right front.
Added some high res dragon photos
Me in the same corner right behind you
Great Pictures SethO, Thanks!
I left some there too the flame imprints on my tires are gone now
But the wear is even and the tires are really soft
Thanks for the pics
At last I found out what all the hub-bub was about the nose art on the spyder some time ago.
IBA #47122
2020 RT Limited Asphalt Grey
