Results 1 to 18 of 18
    Active Member Hamie's Avatar
    Dec 2009
    Austin, Tx
    Default My guide to Audiovox Cruise Control Installation
    Thanks to forum members across multi forums for posting their pictures and sharing information... I used the following pictures as a guide to install my Audiovox cruise control..
    For servo and vacuum canister location:
    For Control Panel mounting..
    For cable to throttle hookup..
    For the vacuum hookup...
    For the wiring....
    This the picture I used for the coil hookup..
    The picture for the Servo switch settings....
    This is my completed installation...
    2019 Ryker Rally
    Springfield, MO
    Most of those were my install pics.
    Inactive User
    Aug 2008
    Cape Girardeau Missouri
    Thanks for the pics.
    I've got an Audiovox electric version on the way but I suspect that many of the connections other than vacume are the same.
    Inactive User
    Jun 2008
    Kitimat, B.C.
    Which cruise controll are you using? the cs-100
    Dec 2009
    Austin, Tx
    Quote Originally Posted by tweeder View Post
    Yes...the cs-100..
    2019 Ryker Rally
    Inactive User
    Dec 2009
    Saraland, AL
    Do anyone near lower Alabama do this install for the mechanical handicap?
    Inactive User
    Sep 2009
    msla mt
    Default ccs-100 install
    Hamie or Lamont, On the wirering diagram., does the gray wire comeing out of the contol box, also go to a switched 12v, as the red ??
    Dec 2009
    Austin, Tx
    Quote Originally Posted by madjack View Post
    That's where I put mine... working great....
    2019 Ryker Rally
    Inactive User
    Oct 2007
    anybody install the electronic one yet? Where is the VSS wire?
    Inactive User
    Jun 2008
    Vail, AZ
    I think so, I believe it was Lamonster even. The controller was NOT enviromentally sound if I remember right, seems as though water shorted it out 2 or more times.
    2009 GS SM5 , Red/Black
    Dec 2009
    West Oz
    Lon, my throttle hook-up. THe cable is held in place by a cable tie and works perfectly.
    Inactive User
    Oct 2007
    Quote Originally Posted by AMTJIM View Post
    I ordered the waterproof skin for it from Murph kits ($5)
    Inactive User
    Oct 2007
    Default control switch mount
    OK, guys... how about everyone posting pictures of how they mounted the control switch for their control. I'm sure there are a lot of good ideas out there. Also, would someone post the dip switch setting for the electronic audiovox cruise control that you found most appropriate? thanks
    Dec 2009
    West Oz
    Inactive User
    Oct 2007
    Freddy,
    How about a close-up of that mount. Can't see how it attaches. Aluminum?
    Dec 2009
    West Oz
    Quote Originally Posted by lonlawrence View Post
    Freddy,
    I'd have to get my son to do the pic thingy. It has a right angle bend at the top and is attached with existing bolt on the controls. It's stainless steel (scrap from his work) but aluminium would be just as good. Having it located there I don't need to let go of the bar as it's just a thumb stretch away.
    Inactive User
    Aug 2010
    Council Grove Ks
    Red face Thanks for the instruction it is beutiful and complete.
    I wish I had found your instructions before I started the install, but I guess that it only made me appreciate the guide even more. Thanks it works great. Ken Daugherty
    Oct 2013
    rome new york
    Quote Originally Posted by Lamonster View Post
    Lamont u want credit for everything lol
