SpyderLovers Founder
Thanks for the pics.
I've got an Audiovox electric version on the way but I suspect that many of the connections other than vacume are the same.
Which cruise controll are you using? the cs-100
![Quote](images/misc/quote_icon.png) Originally Posted by tweeder
Yes...the cs-100..
Do anyone near lower Alabama do this install for the mechanical handicap?
ccs-100 install
Hamie or Lamont, On the wirering diagram., does the gray wire comeing out of the contol box, also go to a switched 12v, as the red ??
![Quote](images/misc/quote_icon.png) Originally Posted by madjack
That's where I put mine... working great....
anybody install the electronic one yet? Where is the VSS wire?
I think so, I believe it was Lamonster even. The controller was NOT enviromentally sound if I remember right, seems as though water shorted it out 2 or more times.
Lon, my throttle hook-up. THe cable is held in place by a cable tie and works perfectly.
![Quote](images/misc/quote_icon.png) Originally Posted by AMTJIM
I ordered the waterproof skin for it from Murph kits ($5)
control switch mount
OK, guys... how about everyone posting pictures of how they mounted the control switch for their control. I'm sure there are a lot of good ideas out there. Also, would someone post the dip switch setting for the electronic audiovox cruise control that you found most appropriate? thanks
Freddy,
How about a close-up of that mount. Can't see how it attaches. Aluminum?
![Quote](images/misc/quote_icon.png) Originally Posted by lonlawrence
Freddy,
I'd have to get my son to do the pic thingy. It has a right angle bend at the top and is attached with existing bolt on the controls. It's stainless steel (scrap from his work) but aluminium would be just as good. Having it located there I don't need to let go of the bar as it's just a thumb stretch away.
Thanks for the instruction it is beutiful and complete.
I wish I had found your instructions before I started the install, but I guess that it only made me appreciate the guide even more. Thanks it works great. Ken Daugherty
