Results 1 to 8 of 8
Thread: tires
    Invalid Emails
    Jun 2009
    birmingham,al
    Default tires
    any idea what kind of tires these are?
    May 2009
    PA
    Not sure myself about the tires, but the exhaust is interesting too.
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by ameobe View Post
    Also it seems to be Streamlined, Maybe it will cut though the air a little better than a out house on wheels
    Aug 2008
    Winchester VA
    That Spyder is COOL.
    May 2010
    Southeren NJ
    If you look closely at the rear fender it says Yokohama... you could probably go to tirerack.com and find the tread pattern and the tire.
    Aug 2008
    Winchester VA
    does anyone know if there are more pics of this spyder? Would like to see more.
    RT-S PE#0311
    Oct 2009
    Orlando, FL
    Doc.........don't get any ideas!!!!!
    Some of these tires are designed for race track only use. This usually means they are optimized for a single use only application. Like Dry Track Only or Wet Track Only.
    They are designed for someone who has a rack of tires and can change them as conditions warrant.
    They are Not designed to give good traction in all kinds of conditions. So they may look really cool but they aren't safe to run everyday on the street.
