Garmin 660 does go through radio via audio input
I purchased Garmin ZUMO 660 GPS for around $630 from cheapest place I could find and the Kewl Gismo mount from Kewl metals. The Garmin ZUMO 660 GPS has a built-in MP3 player (takes place of Ipod) for your listening pleasure. The Garmin requires a 12 volt power source and has an audio out plug that plugs directly into the audio input located in the rear luggage compartment. This audio input feeds directly into the AM/FM radio thus the audio does play through the system. The mp3 mutes when the GPS is giving direction as does the radio...just like a dealer install would do. It works great!!!!!
I chose not to purchase the $125 extra harness required. When I was doing a pin-out for my trailer hookup, I discovered that pin B on the HD10 connnector located on the underside of the left saddlebag is a switched 12V source. It is an orange wire and I traced it back up and under the seat. I hooked the 12V red lead coming from the Garmin to this orange wire (I believe this is CIC2B-B on the wiring diagram for the Lights and Harness. I then put a ring connector on the black Garmin wire and grounded it with the other grounds to a bolt on the right side of bike under the seat. The 3.5 mm audio out wire from the Garmin is not long enough to make it all the way to the rear luggage bag so I bought a 6 foot 3.5mm male to female extension cable. The rest of the wires from the Garmin are not needed for the installation so they get taped up. Anyway, this was not an easy install. The dealer says 1.5 hours and I guess my friend and I had around 20 hours! Most of the panels must come off, all the wires need to be dressed out once the rough-in is complete. I drilled the center pop out on the steering out and then cut a slit to the outside so I could feed the Garmin wire through the hole. A rubber bushing will go around the wire and seal up the hole. Another post I read talks about the Garmin 660 not mounting flat on the Kewl mount. I found this to be true also. I put spacers on the back which required 4 longer screws but hey, that's cheap compared to the $500 I'm saving by not going through BRP.
Anyway, I know I glossed over my install really quick. But what I really wanted everyone to know is that the Garmin 660 can be hooked up and work like it is supposed to without going to the dealer and without buying the additional harness.
gps
I was looking into the 665. Looks like I need more looking into.
Originally Posted by Jornie1
I purchased my Garmin Zumo660 directly from Garmin...not BRP, at around $500 savings. Here in my hand is the only thing you will need to complete the electrical/audio connection for the non-BRP 660. BRP part Number 710 002 182, around $60 from your dealer. Heat shrink included. It's an easy install. I bought the mount from KewelMetal. It almost fits the 660..not quite. The back of the Garmin mount that the 660 attaches to isn't flat on the back, it is notched I solved that problem by fabricating spacers the same depth as the notch. Voila' works great, looks great and I have sound in my RT audio system....Oh yes.. I did buy the corrugated conduit to protect the wiring harness from a local West Marine Store..... Len
sorry to revive an old thread .. so this connector the purple one plus direct into back of a NON CanAM Garmin 660?
so just this cable plugged into the Garmin 660 (NON BRP) and audio plugged into the Garmin 660 headphone out jack and done ? after mounting?
