What's this wire and how do I stretch it?
All,
I sent an email to RT Sales about an hour ago and thought I'd follow up here. The product is very well made but I have one issue I can't seem to track. After installing, ONE WIRE (heavy gauge but doesn't appear to be multiple wire cluster) is very tight (not quite guitar string but close enough).
The wire in question comes out by the ignition, goes through a small clip on the top of the steering column, goes under the rubber boot, and stays up top before I loose it.
I'm guessing this is something to the instrument cluster but can't find the other end so can't lengthen it.
Comments/Suggestions would be much appreciated.
Dennis
