Results 1 to 20 of 20
    Feb 2023
    new york
    Default After suggestions on Essential Tools to carry?
    I'm a new owner of a new 2022 F3T.
    Are there any suggestions on the most essential tools to carry on a week-end trip?
    Last edited by Peter Aawen; 06-18-2023 at 08:49 PM. Reason: Expanded title to briefly ask the question... ;-)
    Faribault, MN
    AMA Membership card, cordless tire pump, factory tool kit, work gloves (so I don't get oil or grease on my driving/ryding gloves).
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Feb 2012
    Spring City,Utah
    I carry 2 12mm wrenches in case of parking brake trouble. I also carry a small electric screwdriver and a #30 torx bit to speed plastic removal, AMA card, Credit card, air pump, tire plug kit.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    You are most likely going to find minimal things here.
    Unfortunately, Spiders are technical wonders for most of us. Others of us cannot get down on the ground or tear off the plastic to get to the problem. A credit card, and a cell phone come to mind for me. Been driving Spyders since they came out. Twelve years in Alaska included. Never had a breakdown that left me stranded anywhere. Lucky for me....I cannot fix the thing anyway. 200,000 Spyder miles on seven various...and I have been good to go.
    The good side....We hear very few major issues with them. The biggest complaint these days is the supply chain, and the competency of many of the dealers.
    Oct 2020
    Vinton, IA
    My advice...., a can of fix-a-flat, some fuses, and knowledge. The first two are obvious and, probably, the only things you can do by yourself on the roadside. Know how your machine sounds and feels, know how far it will go on a tankfull of gas, and know the BRP roadside assistance phone number (keep it in your cellphone).
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    I probably carry more tools that I need. But after hearing of problems with the parking brake release, I recently added a spring hook. That way if I ever need to manually unhook the spring I'm hoping this could make it easier. But hoping I won't need it. Those of you who have had to unhook the parking brake spring can tell me if this would help or not? SpringHook_1.jpg
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
    Dec 2022
    Florida
    Also download the service manual to your phone and get familiar with it, take screenshots of the fuse box section.
    Durham,Maine
    Quote Originally Posted by GRHorst View Post
    All you need to unhook is the cable, two 12mm wrenches. If the caliper is working right just unhook the cable and the brake should release, make sure you have something under the tires if you're on a hill or you may get run over, then you may need a first-aid kit in your bag of tricks!
    2012 RTL , Pearl
    Florida Swamp
    A few of the more popular wrenches. I carry metric and SAE.
    Screwdriver handle with torx, phillips, and other tips in a side pouch.
    Flat tire repair kit and CO2 to air up. Pliers, few other items.
    This is on the bottom of the frunk. Plenty of room on a Spyder to carry anything you want to.
    Got some Zip Ties, a roll of electrical tape, baling wire, and a few of the common small nuts and bolts too.
    Not in the tool bag, but on long trips, always carry water with you. I usually tie a 2-liter military canteen on the luggage rack.
    Last edited by Peter Aawen; 01-19-2024 at 07:28 PM. Reason: hes.I c...; yhti... ;-)
    2019 F3-S , Black & Silver
    Feb 2023
    new york
    Thank you for all your advice and knowledge. I probably carrying more tools than I need, I also overpack clothing on trips. I really need to work on that so I don't overload my new f3t. Thank you everyone, maybe I'll have a useful tip someday.
    Active Member Woodenfish's Avatar
    Feb 2022
    Illinois
    I would guess that a dead battery, a flat tire, and parking brake problems would have to be the top three concerns, so carrying a few things to get you back on the road if those occur without an expensive tow bill is a good idea. I also carry a small Med kit with typical band-aids, ACE wrap, and pain killers. I’m not qualified for roadside surgery but if I should be out and about far from home, decide to do something off the bike for further sightseeing, and happen to hurt myself in such a way, then I would like a quick fix to drive home without further complications. Lastly, I carry a couple of bottles of water and some gloves. I keep all of this in a small fabric automotive trunk organizer that fits in one of my panniers.
    2021 Spyder RT Limited Asphalt Gray Chrome Edition
    2022 Spyder RT Limited Hyper Silver Chrome Edition
    Shoei Neotec 3
    Cardo Packtalk Edge Duo
    Vanquest Gen 2 7x10 First Aid Trauma Pack
    Garage Door Opener
    iPass
    DJI Action 2
    Tackform Anti-Vibe Phone Cradle
    UltraGard Full Covers
    Show Chrome rear trunk lid lift strut
    Noco Genius 1
    Noco GBX Booster X
    Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
    Baseus Cordless Inflator
    Alaska Leather Sheepskin Butt Pad
    Mar 2021
    Arizona high country
    Rather than adjusting the parking brake to release the tension you can just remove this bolt and the arm. I took this pic as I was putting it back together, so the spring was not on yet. Using this method also makes it easy to remove the spring once the bolt is out. Uses the same 12mm wrench (at least on my 2018 F3L)
    Jun 2017
    Rapid City, SD
    Duct tape, baling wire or zip ties, and a Leatherman.
    HE>I
    2017 RT , Asphalt Grey
    Vermont
    I carry the following on my 2023 F3 LTD Special Series:
    (also on my sled) a smart battery power pack that has: mini jumper clamps; built-in LED flashlight; & recharges from any standard USB power port, cigarette lighter outlet, or included wall charger - Power 200 amps continuous/400 Peak amps.
    (Off topic: I also have a 2020 Ski Doo Renegade 900 N/A sled and I take the power pack plus a set of jumper cables, which I have not had to use yet, with me when I go on the trails).
    Deanna
    Current Spyder - 2023 F3 LTD Special - Mineral Blue
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Front Fairing Service Access Door Covers (Carbon Fiber Domed Black)
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    A-arm Daytime Dual Color LED Running Lights with Blinker Module
    Marinco 12 Volt Power Receptacle with polarized leads & slide lock
    Show Chrome Trunk Shock
    LED'S - Run/Turn/Brake Rear
    Former Spyder - 2014 RTS SE6 Cognac - SOLD
    First Spyder - 2012 RTS-SE5 Quantum Metallic Blue - TRADED UP
    Dec 2023
    Oregon
    While not Spyder specific, my toolkit has stayed the same (mostly) for years. Even if just riding local I carry it always. Inflator, tire pressure gauge, plug kit, insta-flat, 9 in 1 screwdriver, essential wrenches, small vice grips, leatherman, zip ties, fuses, JB weld, duct tape, electrical tape, jumper cable. Although I don't ride off road anymore, Murphys law says I'll bust something, somehow, someday and these tools have always gotten me home. And yes, AAA, my cell phone, and some cash will get you there 99% of the time. But the middle of Nevada, NoCal, Oregon, Washington, Idaho and many other western areas have many spots where you won't get any help, cell service, or a tow truck. If you never take your toolkit off the bike it will always be there. And it all fits in a tiny bag. My 2 cents.
    And I carry almost the same kit in my car.
    2019 Spyder F3
    Previous
    2023 Tiger 1200 Explorer
    2022 Honda Goldwing
    2020 BMW 1200RT
    2020 BMW K1600
    2018 BMW 1000XR
    2018 FJR
    2016 Kawasaki Versys 1000
    2013 Tiger 800
    2012 Triumph Trophy 1200
    More that I can't remember right now.
    Brian
    Member Airjohn's Avatar
    Apr 2021
    Hurricane, Utah
    Hello,
    There are a lot of good suggestions on this thread. Have a 2018 F3-Ltd for about 3 years now, and have been riding "Two Wheelers" some 50+ years. Do a lot of riding long distances and out in the "Hinterlands" as well. In addition, have done some Snowmobile riding in the middle of nowhere, and not being prepared can be dangerous. So, a few items to give one peace of mind I have packed on my ride. As Follows......
    1. Tire Repair Kit.............https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
    2. Mini Air Compressor.............https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
    3. Portable 12v Battery Pack (This will jump start your dead battery, run your portable air compressor, charge your cellphone and computer, etc)......https://www.amazon.com/ZEVZO-ET03-St...s%2C183&sr=8-5
    4. Mini Fuse Kit............https://www.amazon.com/Chanzon-50pcs...%2C185&sr=8-33
    I personally have the above items and they are an excellent quality that won't break the bank. These are the items that will help you get out of a jam, such as a flat tire, dead battery, blown fuse, etc. These you have immediate control of the situation that might arise. For all others maybe a good "AAA Card or the like" in your wallet would come in handy.
    Good Luck, and Happy "Spydering" on the roads.
    Airjohn,
    Retired Spyder Rider In Utah...
    Feb 2024
    Tennesse
    A charged cell phone
    AAA Membership with motorcycle coverage (towing, flat repair, and fuel if you run out)
    wallet with cash and credit cards
    Mar 2021
    just carry a 13mm and remove this one bolt to disconnect the parking brake.
    Last edited by Peter Aawen; 05-22-2024 at 01:59 AM. Reason: Attach is there, just (STILL!) not displaying?? :-/
    Bossier LoUiSiAna
    No bashing intended; tools only good if know what your doing, OEM tool kit plus AUX kit & extras, https://www.lamonstergarage.com/tools-5/ will get you started building AUX kit https://www.amazon.com/dp/B07ZFQJQRV/ref=tsm_1_tp_tc
    , recommended for entire household: https://americanmotorcyclist.com/
    Membership with roadside assistance (can be long waiting, still better than NO HELP AT ALL) charged jump pack & back up battery/power source for cell phone (not necessary same unit) a good ratchet strap or two(various lengths if you like) possibly https://www.findmespot.com/en-us/
    unfortunately loading up with more tools decreases available storage. Simply narrow down by what your willing to attempt on side of road, or having towed & fool with later. **not listing hydration & snacks(as are standard travel requirements& first aid kit)**
    Oct 2023
    Port Hadlock, WA
    Veery impressed! Thank you for sharing.
