Results 1 to 10 of 10
    Jul 2023
    Kentucky
    Default What is this on the front wheels? A spacer, or what?
    I am a new Spyder F3-S owner. I bought a 2015 this past July and am loving it. I was doing some cleaning on the front wheels and was wondering what this part is? It looks like some kind of wheel spacer. Thanks.
    Quote Originally Posted by KYJim View Post
    I'm 100 % sure but I think that/ they are a Centrifugal wheel / tire balancer ..... Look at LaMonsters vendor page and see what His looks like..... if they are - use them,because that may be the only balance you have for the front wheels ..... Mike
    Mar 2017
    Salisbury,NC
    yes, those are the Centramatic wheel balancers. put them back on, helps keep wheel balanced
    Jul 2023
    Kentucky
    Thanks for the info. They seem to be working. Neither of the front wheels have any weights attached.
    Durham,Maine
    Keep them on and they will be fine!!! You'll never have to balance a tire again.
    2012 RTL , Pearl
    Vermont
    I have a 2023 F3 LTD Special Series , and my tires have weights on the rims.
    I did not see the Centramatic Wheel Balances on mine.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Deanna
    That's because they arn't from the CanAm factory.....ie. " not oem " ..... you have to purchase them from " centramatic " ..... Mike
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Those are kinda pricey these days ..Centramatic lists them as $395 for a full set of three 2F 1 R
    My tire guy had no issues mounting and spin balancing my new Continentals for the front of my 2019 RTL. $50
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    Deanna
    https://www.lamonstergarage.com/wheel-balancer-4/ Lamont has sold those for years, T.P.
    May 2023
    WV
    Quote Originally Posted by WRCLVR View Post
    Many Spyder owners, even with their tires perfectly spin balanced, still have vibrations coming from the tires/wheels. Could that be solved with premium tires or better rims? Maybe. However, many found slapping a set of Centramatic's on solves those issues without having to spend all that money on trial and error, especially if you just bought a new Spyder and already have to fork out money for new tires.
    Last year I bought a 23 F3-S, and for the first 4k miles had lots of vibration. I had my tires checked for balance and they were fine. My next options were to buy new tires for $250+, but there's no guarantee that will fix the issue; if not, I'd also need new rims, which is another $250+. Or I could grab a set of these for $250 @ Lamonster, which I did, and it solved all my issues. My F3 rides silky smooth now!
