Results 1 to 13 of 13
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    Default What do I need for Brake pad replacement?
    First time brake job.
    Do I need to compress the calipers?
    If so, can it be done without taking the brake reservoir cover off?
    Thanks ahead for the replies
    Last edited by Peter Aawen; 05-15-2024 at 06:09 PM. Reason: Removed Prefix - this is not a HowTo: DIY thread... & expanded title to briefly state the reason for the thread! ;-)
    Durham,Maine
    What year and model??
    2012 RTL , Pearl
    Jun 2019
    Wisconsin
    Sorry 21 RT
    Quote Originally Posted by sgerksinwi View Post
    Sorry 21 RT
    You could avoid ever having to do all that ^ again just by following the directions in the Sticky.
    https://www.spyderlovers.com/forums/...your-Sig-Line!
    Durham,Maine
    https://www.youtube.com/watch?v=VbfFLIQ_PsU
    You tube is your friend!! Have fun, easy job!!
    2012 RTL , Pearl
    Jun 2019
    Wisconsin
    That's the one I watched.
    He did not do the things I questioned.
    So the answer is No to the reservoir cap?
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    In the video you see him pry the old pads on front wheels appart with a flat screwdriver, that will compress the pistons.
    Rear piston is screwed in by using a tool.
    As I recall from last time I did this, I took reservoir caps off. Just keep the surroundings clean so no dust or stuff goes in the fluid.
    Brgds Martin
    Typically, if you've worn your pads down enough to require replacement, you have added brake fluid to the reservoir. When you compress the caliper pistons, this added fluid in the system returns to the reservoir and can overflow, which you want to avoid. We suck some fluid out of the reservoir before doing a brake job to prevent this. Then, if the fluid is still serviceable, we suck all the fluid out of the reservoir when we are done and replace it with new fluid. This extends the life of the brake fluid and can prevent the need to bleed the brake system as often.
    We've also seen, several times, people have added fluid to the top of the rubber fluid expansion/displacement cover. Which simply pools above the reservoir and does nothing for the brake system. Don't do that!
    Jun 2019
    Wisconsin
    Ron
    Glad you chime in.
    As usual my question are answered.
    Call you soon if I need parts.
    Jan 2018
    mondovi wi
    I never have, but you do need to screw the brake calipers back into the home position. I just use a needle nose pliers.
    Quote Originally Posted by bobfeeney View Post
    Screwing the piston, CW, back into the caliper is required only for the rear caliper. One can simply press the pistons into the calipers with finger pressure on the front calipers.
    True if all goes well. But it is not unusual for the front calipers to take more than finger pressure to push them back into the caliper. Needle nose pliers can work on the rear caliper if the piston is free. But again, it is not uncommon for it to take a good deal more torsion for retraction than can be achieved with pliers. It all just depends.
    But whatever you do, NEVER turn the rear caliper counter-clockwise! Not even a smidgen. Though not the end of the world, doing so can give you a great deal of grief.
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    Buy BajaRon's Brake Tool. Makes it much easier to turn the adjuster.
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    FOBO 2, Trunk rack, Afterburnerz taillights
    Drinks2go cup holder, replaced the seat strut
    Garmin Drive Smart 71 GPS, Large brake pedal
    White pulley, Pedal Commander, Trunk Strut
    Laminar Lip wind deflector, side windshield wind deflectors
    Home made belt guard, Shorty antenna
    Show chrome wide windshield, Belt dampener
    Top cuffs and Mirrors
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
