Results 1 to 6 of 6
    Active Member mstella101's Avatar
    Jul 2013
    Glen Ellyn, Il
    Unhappy Can't Unlock passenger seat - is there another way/work around?
    Is there another way to get the passenger seat unlatched and off ? Isn't working with turning key from dash. I was wondering if there is a work around. Thanks.
    Last edited by Peter Aawen; 05-10-2024 at 10:25 AM. Reason: Expanded title to briefly ask the question/s... ;-)8
    Bossier LoUiSiAna
    Might have put some pressure on seat while trying key
    Active Member JB62's Avatar
    Feb 2024
    Dover Delaware
    Quote Originally Posted by mstella101 View Post
    To remove passengers seat you need to raise the drivers seat and reach under it to 2 tabs on the passenger seat that you have to push to remove it then just lift on passengers seat. PS the driver seat has to be up to get it out. Just turning the key does nothing to the passenger seat.
    Oct 2019
    Illinois
    That might work on a RT, but on a F3 it's a turn of the key plus try pushing down right of center on the passenger seat as you turn and push the key.
    Feb 2024
    Dover Delaware
    Quote Originally Posted by Nomad2go View Post
    ok I only have experience with the RT
    Jul 2013
    Glen Ellyn, Il
    Thanks , I had to take a couple panels off anyway, so I ended up lifting up the key cover and VOILA. Got it unlatched.
