Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Active Member JB62's Avatar
    Feb 2024
    Dover Delaware
    Honestly, it's not the dealership's fault.
    Fussing/complaining at them will do you no good at all. It might even be detrimental to you in the future.
    BRP is who everyone needs to be fussing at.
    I didn't fuss at the dealer, I talked to them and they gave me the phone number for customer service at BRP. I called BRP and spoke to them and discovered my dealer didn't have a direct phone number for them. Now they do have a direct dealer phone number. I was also told from BRP that I can be compensated for the down time. My dealership is going to give me a loaner until its fixed, you are right the dealer is doing the best they can.
  2. #27
    Clinton, MS
    I have a feeling that BRP is going to be doing several parts shipments before this situation is resolved.
    2019 RTL Phoenix Orange
  3. #28
    Feb 2024
    Dover Delaware
    BRP sent me an email asking my opinion and I told them the truth about what was happening as well as telling them about other 2024 owners being annoyed with the apple car play issue. so maybe they will get it in gear
  4. #29
    Aug 2018
    Piperton, TN
    I feel for you guys. I really do. Makes me really appreciate my 2021 that has had no issues.
  5. #30
    Mar 2024
    North Carolina
    So I had same issue and dealer replaced with new battery and as they were backing it out it did it again. After 2 hrs it is the dash cluster. Mine is a 2023 F3 Limited just purchased new last month. I kept getting DPS code, engine malfunction and VSS error. Then it will be fine. Short runs it was worse. Had to wait to restart and pray it would.
    2023 F3 Limited , Plasma Red/ Platinum Edition
  6. #31
    Feb 2024
    Dover Delaware
    Quote Originally Posted by Wdaniels View Post
    Start a case with BRP, I did and eventually the dealership gave me a new Spyder
  7. #32
    Mar 2024
    North Carolina
    We got the call that the dash was successfully replaced and I could pick it up. Funny how he said there is no cost to us. I wanted to reply Of course there won't be since we only had the bike for 3 weeks. Anyway we will see how it goes.
  8. #33
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Yah, you're bloody right no cost! It's still under warranty, as it was sold only 3 weeks ago.
    Wdaniels - so is it fixed? Has it stayed fixed? Appreciate it if you keep this updated. My 24 S2S should be getting a new cluster in today. So I'm understandably concerned...
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
  9. #34
    Active Member slhanks004's Avatar
    Nov 2022
    Gilbert, AZ
    3 weeks ..... make the Stealer give you a new Battery ..... Then after you get it home add Star washers to the Batt. terminals ....good luck ....Mike
    The dealer will install another crappy, low-quality battery.
    Scott (slhanks004)
    Gilbert, AZ USA
    2022 Spyder RT Limited - Carbon Black
    • Pedal commander
    • Baja Ron sway bar
    • TricLED tail lights
    • TricLED driving lights
    • Corbin seat
    • BRP rider backrest
    • Lamonster topcuff (2) w/ RAM mounts
    • 12v/USB docking station
    • Garmin Zumo XT
    • RLS cat delete pipe
    • IPS highway pegs
    • IPS belt tensioner
    2022 RT-L , Carbon black
  10. #35
    Nov 2022
    Georgia USA
    Well my dealer replaced the crappy Jailiu battery with a Yuasa one for me under warranty. The new cluster is working fine. However, I have codes on it that can't be erased according to the dealer. Just a few days ago, I got the P0195 Line Pressure Low Code, but the bike did not exhibit any issues for that issue. I do the following once ready to start a ride - start bike using the recommended right grip twist and starter button; then before starting off, I press the parking brake off; depress the foot brake; and then shift to reverse or forward as needed. This helps reduce the clunk a little...
    Still no answer from the forum as to what the P0195 code is. SA said just bring it in... Life isn't letting me do that right now tho'......
    Last edited by Peter Aawen; 06-02-2024 at 07:59 PM. Reason: Codes are all 1 alpha followed by FOUR (4) alpha numerics. ;-)
