Results 1 to 16 of 16
    Apr 2020
    Dayton, Ohio
    Default Has anyone tried Different Batteries, like a NOCO 600A Lithium? How is it working?
    2023 Spyder RTL, 3rd new battery within a year. The cheap China battery didn't make it at prep during purchase. Interstate battery (300CCA) was put in by dealer, as they told me that they didn't have a YUASA battery in stock. Still had starting issues. Thinking that it was because the Interstate battery was only (300CCA), I purchased a new YUASA battery (350CCA). Still having starting issue and decided to take it to another dealer to see what the problem is. Was told that my new battery is bad, and they put in a new YUASA Battery (350CCA). The service writer, told me that the newer model's have issues with batteries if they are just a little weak. So here's my question, Has anyone put a NOCOŽ Battery 12V 600A Lithium in their Spyder? How is this working out for you? Next question, Lithium batteries take a different type of charger. How does the charging system on the Spyder charge a Lithium battery when you need a lithium charger/tender that is different than a standard charger/tender? TIA.
    Last edited by Peter Aawen; 05-04-2024 at 10:03 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Quote Originally Posted by Rottman View Post
    Last question first .... The charging device you will use CONVERTS household AC to 12v DC .... the Spyders alternator only makes 12+ v. DC ..... I just bought that NOCO 20LP for my 14 RT ..... which now starts instantly ...... Mike
    Durham,Maine
    I to have swap to the Noco last year, so I am still on the fence on this one! I love the charger I got; the battery too; but I'll hold my review 'til later.
    2012 RTL , Pearl
    Jan 2022
    North Dakota
    Put a NOCO this spring. So far its great. Year or two I'll know more.
    2021 RTL
    2021 RTL , Asphalt Gray
    SoFlo
    Not a NOCO, but installed a Shorai in our Spyder. Nearby friend, he installed the NOCO.
    Wanted to add though, your battery failures may also be related to a failed alternator clutch. Last year I helped a person, stranded on their trip. After the shop spent weeks changing parts per what BRP told them, turned out to be a failed alternator drive clutch.
    Passes all the voltage checks but slips and does not charge the battery under greater loads.
    Dec 2020
    Hartwell, Ga
    I have the Noco NLP20 in mine and love it. It's been over a year with no problem at all.
    Make sure that you have a maintainer for the lithium battery also if you go this route. Noco make an excellent product for that also.
    Durham,Maine
    And works on all of the rest of the style battery's also!
    2012 RTL , Pearl
    Feb 2013
    Edinburg, TX
    On 11/08/22 I installed a battery from O'Reilly Auto Parts for $119.95 plus tax. Only guaranteed for 12 months but after 18 months now, it still spins starter at full speed. I forget the name of it, but the physical dimensions exactly match the Yuasa. I don't use a battery maintainer.
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    Active Member BoatFixx's Avatar
    Oct 2023
    Port Hadlock, WA
    I have one.
    Works fine.
    I maintain with a CTEK CT5
    2023 Sea2Sky
    Apr 2020
    Dayton, Ohio
    Thank you for the information.
    Interesting about the alternator drive clutch. I'll keep that in mind.
    Last edited by Peter Aawen; 05-05-2024 at 11:01 PM. Reason: Merged immediately consecutive posts... :-/
    Jun 2017
    Crossville TN
    Duralast here from Auto Zone $110.00 been 4 years on a battery tender when not in use.
    Dave
    2013 RT Limited
    Lamonster FBB with larger gripper pegs
    Value Accessories dah mount
    Custom Dynamics High Mount brake light
    BRP passenger arm rests
    Oct 2021
    Wichita, KS
    All chargers convert 120 volts ac to (roughly) 12 volts dc. The difference is in how they accomplish this task.
    Rottman, I installed the NOCO 20LP in my Spyder from LaMonster and it has never turned over so well. The difference is very noticeable. I will never go back to lead acid. Watch this video https://www.youtube.com/watch?v=XcVj9262zjg It will answer all your questions.
    Peter Pan has struck again!
    Mar 2015
    Fritch, Tx
    I put an Odyssey PC680 in 6 months ago. It's working just fine. It does not have quite the CCA of the OEM battery, but I chose the PC680 based on its longevity in my motorcycles. The last one I changed out on the R1200C lasted 7˝ years. Comparing that to the last Yuasa that lasted only a little over three years and the choice was easy.
    Those who say " I can't" will always be right.
    Jan 2024
    Texas
    I bought this $70 MightyMax in February, and so far, no issues at all.
    https://a.co/d/c4rRk2p
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system
    Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock
    May 2021
    Camano Island, WA
    We installed the NOCO Lithium NLP20 batteries in our 2020 RT's recently, it completely eliminated the sluggish cranking, even when the engine is still fairly warm. The compact NOCO GENIUS2 chargers are compatible with AGM/GEL batteries as well LiPo batteries, haven't had to use them on the new batteries... yet.
    Apr 2020
    Dayton, Ohio
    Thank You Kamjam
