The installation of the spring worked on the seat of my 2021 RTL but not on my 2022. The spring just slid all the way down and didn’t fit the strut the same way as the 2021. I will be ordering the improved replacement part for both seats from SlingMods. I’m not a fan of that spring. The trunk lift replacement I purchased from SlingMods has worked really nicely. The OEM trunk lift strut has worked flawlessly so far on the 2022.
2021 Spyder RT Limited Asphalt Gray Chrome Edition
2022 Spyder RT Limited Hyper Silver Chrome Edition
Spyderco Paramilitary 2
Vanquest Gen 2 7x10 First Aid Trauma Pack
Garage Door Opener
iPass
DJI Action 2
Tackform Anti-Vibe Phone Cradle
UltraGard Full Covers
Show Chrome rear trunk lid lift strut
Noco Genius 1
Noco GBX Booster X
Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
Baseus Cordless Inflator
Thanks so much for the tip! I just ordered the springs from Amazon for $8.52 but that's a whole lot better than what a new ShowChrome strut costs! Best wishes!!
Reason: 2022 RTL
Danzguy, what Spyder do you have year, mod? I have a 2020 RTL, want to know if the springs you got from Amazon will fit my strut.
its in his SIGNATURE line.................. 2019 RTL
Ozzie Ozzie Ozzie
Or is it in the 'Last edited by...' line at the bottom of his post, where just a few minutes after Danzguy originally posted, he added as a reason for his edit "Reason: 2022 RTL"
Mind you, either way, bikerbill's question is still a good one, seeking clarification on which Spyder year & model Danzguy has, as it does!
Thanks gentlemen, whoops, not sure how I missed that.
The spring was put on a newer Spyder, 2020 and above.
I doubt that it will work on the older spyders as I think that they had a longer cylinder/strut.
Well, I need to check this out since mine is a 2020 RTL. Shooter, can you be specific on the Amazon spring that fits, I did a search and couldn't find it.
Ozzie Ozzie Ozzie
The pics show the spring that the original poster in this thread used on his 2020 RT (middle pic shows the part #):
Originally Posted by PW2013STL
The driver seat strut weakens over time and on my 2020 would not stay up making filling the gas tank harder. I ordered a different strut from McMaster Carr that is stronger. Works well except the strut being longer the seat arm catches the side body plastic. Doesn't hurt anything, but I don't like it.
When my wife's 2021 seat started to not always stay up I looked for a different solution. I found a spring at Ace Hardware that works great giving the stock strut the needed help to stay up.
Dammit! The pics were meant to show in the quoted post too!! No biggie, just click on '<<First' in the page number bar up above the top right of the first post on this page - that'll take you back to the first post in the thread, where the pics are displayed.
K80shooter's post #14 includes an Amazon link too:
Perfect Peter, many thanks.
Does anyone know of an upgraded strut for the seat of a 2020 RT-L like the one for the tour pack?
Reason: Removed Post title after merge into 1 of the many already existing threads ;-)
I got this at Amazon $15 for 2
Search fo:
C1615046 7.5 in, 40lb Gas Struts Spring Shocks by IAQWE
Some of the vendors on this site have the new seat strut listed from Showchrome/Big bike parts. P/N 41-269.
Thanks PW, I think this what I'm looking for. I've been fussing around with this problem for a while now spending a few $ here and there and getting springs that don't work, and don't fit. Not spending $40 right now on a new strut, pulling off tupperware and up under the machine, maybe later. Those picture sure helped.
There is no tupperware to be removed on the 2020+ models. I did mine without removing anything.
