What is this plastic rod? Should it be attached somewhere?
I was under the 2023 Spyder RT-L today and noticed this rod that appears to need to be attached with a nut and bolt to the hole below it.
Can anyone tell be what this is and what purpose it serves? Could you recommend taking it in for service or just buying a bolt and nut to reattach?
Thanks.
Reason: Expanded title to briefly ask the question/s... ;-)
Mike Branscum
2023 Spyder RT Limited Carbon Black
I'm pretty sure that's the connecting rod to the ACS system. You have a Ltd, so it has the Self-leveling system .... Have you noticed that it wasn't working????? .... Mike
Look at a parts Fiche' to see what size it is and get one anywhere they sell nuts and bolts - Ps. it's probably METRIC.
Thanks. I’ll check that out. Yes I have notice the ride was a little rough.
Mike Branscum
Thanks.
Did you have a new rear tire installed recently? It is disconnected as part of doing a rear tire replacement.
Originally Posted by Snoking1127
Did you have a new rear tire installed recently. It is disconnected as part of doing a rear tire replacement.
This was a new purchase around three weeks ago. Is this common item they miss on new set ups or should I be worried?
I reconnected and ride is much smoother now.
Mike Branscum
That is one step that gets missed often during initial assembly. It was one of the first things I checked on my F3. My previous RT had it too.
2012 Viper Red RT-S (Sold)
2020 Ryker Rally
2023 Plasma Red F3 Limited
When you get it hooked up correctly you are going to notice a tremendous improvement in ride quality. Based on the pic your air bag is completely collapsed.
And hopefully not pinched and leaking!!!
My right hand up! Yes! My air bag link was not hooked up by my dealer when I took delivery! (I heard the air pump running and then it stopped!) My luck the dealer was closed, so once I got home, I looked in my tin cans of nuts and bolts and found the right metric bolt to hook it up!
2016 Spyder RT-S Special Series (black)
Garmin Zumo 590 GPS with Mounting Kit & Locking Plate
Battery Tender Jr
Full & Half Covers
Foam Grip Covers
NBV Highway Brackets with Black Dually Trident ISO Pegs
3- Piece Lid Net Set
Baja Ron Sway Bar with Aluminum End Links
Magic Mirror’s
Doc’s Vibration Damper
Air Ryde Rock Armour Cup
Missing Belt Guard
Dual USB Charger with Digital Voltmeter Rocker Switch
IPS Axel Caps Front (inner) & Rear
GoldPlugs MP-01 & MP-18
Yuasa YTX24HL-BS Battery
Battery Post Risers
Tie Down Rings
Show Chrome Rear Trunk Shock
2- Beaded Seat Cushions
Tinted Sport Windshield & Side Cargo Bag Set (stored in a box)
It's a '23, let the dealer fix it. If you do have a damaged air bag, they could refuse to fix it because you worked on the system and now it's broke. Worst case for sure, but some dealers are always in the CYA mode.
Now you need to take it back to the dealer and have the ride height calibrated with BUDS. Your Spyder is not right until it is calibrated.
Peter Pan has struck again!
Well whoever assembled your Spyder .... didn't connect it .... You should let the salesperson you did business with know about this ..... Glad you got it fixed ....Mike
Agree, good thing you took the before you put it back together picture!
What years does this apply to? Should I take the tupperware off my 2019 RTL to verify mine is hooked up?
2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
Slingmods USB and QuadLock phone mount with vibration dampener
Highway pegs
Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
Drink2Go front/rear Cupholders
3D printed Turn Signal/Shifter caps
KOTT Grill covers
LED Headlights + LED Foglights
High Mount Trunk brake/turn lights with brake strobe
Pedal Box+ w/BT
Show Chrome gas shock for rear trunk
Foam Grips
Red Rim Covers
VIOFO MT1 Front/Rear Dash Cam system
Upper Radiator Exhaust Block (SpyderPops)
ShowChrome Heavy Duty seat shock
It's not the YEARS that matter ..... only if you have a model that has the " ACS " system ..... The Rt's that have the ACS are the ones that have the Auto Leveling system PUMP .... all the LTD's have them ....Mike
No need to remove any body panels. You can look up under there to see it. You would be aware if it was not hooked up. You would be experiencing a very rough ride otherwise. Many threads on here about it.
