Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    Quote Originally Posted by rick_w View Post
    I got a sachs sg359011 of Ebay several years ago. They work perfect and will last way longer than the original. Just go to Ebay and do a search, $15 to $24.
    I came across a couple of product descriptions that indicate Sachs (also Stabilus) is actually an OE supplier so that may be the one BRP uses. Here's a link to the one from Lift Supports. https://www.liftsupportsdepot.com/17...with-pm3787-w/, and on Amazon, https://www.amazon.com/Can-Am-Spyder...s%2C178&sr=8-4.
  2. #27
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    Question
    The strut is not holding up the seat and I have taken it out to measure length and possibly find part number on it.
    I could find some info printed on the original strut so I took it with me to a shop that have lots of types of struts.
    The only thing preventing me from buying a new one was that there was no info on how many Newtons the original strut was delivering. Does anyone know ?
    Last edited by Peter Aawen; 03-21-2024 at 05:14 PM. Reason: Removed Post title - they mess with Searching! ;-)
    Brgds Martin
  3. #28
    Here's an earlier thread that might help a bit more:
    https://www.spyderlovers.com/forums/...ighlight=Strut
  4. #29
    Apr 2022
    Southern Norway
    Default Temporary 3D fix.
    As I have to wait for new strut I powered up my 3D printer again.
    Brgds Martin
  5. #30
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Stubby View Post
    I just use a scrap piece of 1 x 2 cut about 6 inches long.
    Lays flat on the left side under the seat when closed.
    Works great, and about as cheep as it gets.
    Yep, works for me too, other than mine is a round dowel about 3/4" in diameter. One end slips into hole on left rear. I tacked a rubber bushing on one end to keep it from slipping. Might get around to painting it black one of these days.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
  6. #31
    Oct 2020
    Arizona
    Slightly shorter, once the seat starts up, it does it all on its own.
    https://www.amazon.com/dp/B093H4QHV6...t_details&th=1
    Top case strut:
    https://www.amazon.com/dp/B01MDPI3O9...roduct_details
    Did all three recently. That is both seats and the top case on the Asphalt Grey one.
  7. #32
    Sebring, FL
    Sounds like my experience right down to the wood prop. The OEM was replaced by the dealer under warranty, the second one failed soon after replacement. I was not gonna waste another day at the dealer and have it fail too. Freaking stick works every time.
  8. #33
    Durham,Maine
    I used an aftermarket prop, and would never use anything else, works great!!
    2012 RTL , Pearl
  9. #34
    Sebring, FL
    Mikey, I've said more than once, I do love my 2020 RTL, but holy cow, you'd think that BRP would wake up and do this one little thing right and not inconvenience the customer. I do understand that BRP is big, way to big even have this on their radar.
  10. #35
    Mar 2019
    NEBRASKA
    2012 RTL 14 RTS , Pearl White @ Pearl White
