When did you replace your belt tensioner Roller?
Coming up on 15K shortly and thinking ahead about when to change the roller. What is general opinion when to do this?
Have to order some other stuff from Lamonster and thinking on ordering a roller while I'm at it.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Have to order some other stuff from Lemonster and thinking on ordering a roller while I'm at it.
Actually, you can't because the belt tensioners on the Spyder don't have rollers. You can, however, replace the rollers on a belt dampener! Sorry, just a pet peeve that I know I'll never win. Nothing personal...
i have 50000 and wife has 30000 on our 21rtls no problems so far
I would order the replacement to have on hand and just keep check on the one on the Spyder. I just have made a habit of once a week reaching under and lifting the roller and spinning it to check for smoothness.
Reason: smootness ... ;-)
Hahahaha……onya Ron.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
I checked the dampener on my 2020 RTL, at about the same mileage, and found one of the two bearings to be bad. With a drive belt circumference of ~110" and Lamonster's roller at about 5.5", those little suckers are really spinning!
Once the roller is off, they come out of the housing easily, I used a socket & wooden mallet to tap them out after removing the snap ring. I replaced them (& the ones in my backup roller) with SKF 6202 2RS C3 Deep Groove bearings; they have the highest rpm rating I could find. I found them reasonably priced on Ebay. Good luck!
2020 Spyder RT Limited; Deep Marsala/Chrome
Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
General Altimax RT43 215/60/R15 on factory rear
Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
Extra LED lighting and misc. to suit my needs/wants
I somehow knew you would say that!!!
Reach up there every now and then and see if the bearings are starting to feel rough when you spin them, you'll know when it's time. If it's right after a ride they feel warm, but they should never feel hot! They should spin smooth, not rough! Shaken, not stirred!
Bless you my son!
Bless you my son!
Guilty as charged! A creature of habit, (and lost causes) I suppose... I think "A Rose By Any Other Name" may apply here.
Ozzie Ozzie Ozzie
....Guilty as charged! A creature of habit, (and lost causes) I suppose... I think "A Rose By Any Other Name" may apply here.
Whadda you mean with this bit, Ron?? And TWICE! Are you piking out on me??
C'mon, suck it up! None of that 'defeatist attitude'!
We WILL WIN & get thru to everyone eventually!! Just keep the goal in sight, you know we'll make it! Hang in there, keep on slugging; we've come so far, it'd be a shame to give up now when we're sooo close! You only 'lose' when you stop trying! There may come a day when we can no longer, but TODAY IS NOT THAT DAY!
Be Positive - it's a Belt DAMPENER, not a belt tensioner - the tensioners/aligners on the far ends of the swing arms! The Belt DAMPENERS have rollers! You got this! I'm with you, and there are more! Together, we WILL prevail!
We WILL WIN & get thru to everyone eventually!! Just keep the goal in sight, you know we'll make it! Hang in there, keep on slugging; we've come so far, it'd be a shame to give up now when we're sooo close! You only ' lose' when you stop trying! There may come a day when we can no longer, but TODAY IS NOT THAT DAY!
I suppose you're right. There are still a few of us left! Every one we can convert is a victory!
Looks like BRP calls it an "Idler Pulley" or am I reading this wrong? Whatever it is, we all know what we're writing about. LOL
https://www.canampartshouse.com/oemp...1/idler-pulley
Thanks all for the feedback and Mikey, your suggestion about feeling of the roller every now and then makes a lot of sense to me.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Hey it is a tensioner when you are backing up. I wonder if CAN AM actually tried one on the bottom of the belt. I do know that when I installed at spring loaded roller on my first 2018 Spyder RTL it cured the harmonic belt sound at around 45 MPH. The recently purchase 2018 RTL had one already installed. BTW it is fun to challenge Honda and HD trike owner to a race in reverse gear.
FWIW, Jacob at Lamonster recommended replacing their beefier roller every 15K miles.
2022 RT Sea To Sky
My OEM roller failed at around 10,000 miles, scored the drive belt. I replaced it with the Lamonster roller which is still going strong with 36,000 miles on the bike now. Maybe I'll order a replacement now just in case...
My Mods:
Elka Stage 5 rear shock with spring preload adjust
Monster Stage 2 ECU
Pedal Commander
RLS cat delete
Baja Ron sway bar
Baker Air Wings upper and lower
Viking saddle bags
Third pegs
Vredestein tires front and rear
Mad Stad windshield
X-creen windshield deflector
Front and rear drive cam
Garmin Zumo XT
Heated gear wiring
Lamonster LED headlights
Lamonster LED foglights
Lamonster frame mount cupholder
BRP heated handgrips
Lamonster drivers backrest
BRP passenger backrest
Lidlock handlebar end helmet locks
Barkbusters Storm handguards
Such a big PIA to replace on the 2020+ RT's
2022 RT Sea To Sky
I zip tied my dampener up to the frame and off of my belt and adjusted the belt to where I had the least amount of annoying vibration. Didn't and don't trust those little bearings at all!
