Results 1 to 4 of 4
    Jan 2024
    Texas
    Default 2019 RTL - getting leaves out of grilles?
    Today’s petty question: How do you all get the leaves out of the bottom of your grills that get stuck in the crack where the body meets the grill? It seems like they could have left this gap a wee bit larger so leaves could fall back through easily enough.
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system
    Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock
    Danbury Connecticut
    Quote Originally Posted by Allen42 View Post
    You can use a shop vac to vacuum them out, followed by a good flush from a garden hose and spray nozzle. Once it's clean, I'd recommend installing KOTT grills. There are a number of flavors of grills, either stainless steel or black, some with logos and others without them.
    Here's one example:
    https://www.lamonstergarage.com/can-...019-lamonster/
    Here are many others:
    https://canamspyderaccessories.com/r...nt-lower-side/
    IBA #47122
    2020 RT Limited Asphalt Grey
    Faribault, MN
    Though if you're not gonna use 3Wheels ideas (I have the KOTT grills from CanAmSpyderAccessories.com as I liked the ones with R/T in the grill.
    You can use a spray that Air Conditioning techs use to clean out the radiator grills on HVAC systems, it dissolves the bugs but not the paint etc.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    I agree wholeheartedly!!! Spyderpops KOTTS grills were one of the first farkles I added.
