Results 26 to 50 of 51
  1. #26
    Northern Kalifornia
    You can't use my or BK911's procedures at these new fuel pumps. The pumps flow the fuel so fast that you can't top off after the first automatic shut off. I've wrestled with these dam things until I'm blue in the face. I've tried I don't know how many ways to stuff that extra gallon in and at the new speed and volume, the pump won't allow it. So, I fill up at the older mom & pop stations that have the older pumps. If you cut a 1" slot in a square piece of tin it will help hold back that rubber condom on the pump nozzle and make the last gallon go much easier on the older pumps.
  2. #27
    Sep 2020
    Middletown, NJ
    If you want to defeat the 'condom' used on many pumps look into one of these.
    https://mccuff.com/
    I use the Sport model.
    2020 RT base , Chalk White
  3. #28
    Oct 2022
    Jacksonville, IL
    I have one more observation that I have noticed. Some of the gas stations have a slant to the apron and I have noticed that if my bike is in a nose up orientation I will be able to put more gas in. I thought I was getting tremendous gas mileage but only on that fill-up. In a nutshell don't depend on data from a single tank. The more data you have the more confidence you will have in your data. Luckily my warning light is pretty consistent and conservative as I have been in areas where stations are far and few and knock on wood I have never ran out.
  4. #29
    Oct 2022
    Jacksonville, IL
    Is there any danger of damaging the evap canister by excessive topping off? I damaged mine on my car where it needed replaced on my Ford Focus. Luckily it was covered by warranty.
  5. #30
    Feb 2020
    Minnesota,USA
    I don't believe you can over fill the 2020RT + to effect the engine. If I can get it in the tank it's good to go!
    My 2cents worth, Bill
    10W40 Amsoil Synthetic Motorcycle oil
    If in Doubt, Don't Do It!
  6. #31
    Quote Originally Posted by jjc54 View Post
    The V-twin Spyders had IMHO a design flaw in/to the EVAP system the placement of the hoses allowed Gas to enter it and contaminate it ..... it was fixable (I have pics in an album that showed how) ..... the 1330 engined Spyders had/have a different hose configuration, so it's not going to happen on those .... Mike
  7. #32
    Sebring, FL
    Is there a danger to over filling, say 'almost' to the cap?
  8. #33
    Sebring, FL
    I asked the question above about over filling, but reading yours, 'filling to the lip', answers my question.
  9. #34
    Using the " reply with Quote " feature , will let everyone know ... what post you are referring to ..... Mike
  10. #35
    Sebring, FL
    I'll keep that in mind, referring to your post #11.
  11. #36
    Northern Kalifornia
    Does anyone remember when our gas tanks didn't have a gas gauge? How'd we ever get along without one? Remember removing the gas cap and sloshing the gas back and forth to judge how much gas we had? Yeah. One of my dirt bikes had a transparent tank so I knew pretty close to just how far I'd have to push it. Thank the Lord most of us don't fly airplanes.
  12. #37
    .... but remember those tanks had a REAL RESERVE valve on the tanks ..... Mike
  13. #38
    Apr 2012
    Greenville, SC
    Most of my 2-wheeled motorcycles didn't have a gas gauge for sure. You just learned about when you'd run out and go by trip odometer. Or when they sputtered you flip to reserve and start looking fast for a gas station!
  14. #39
    Northern Kalifornia
    Oh boy, do I! Just enough to get you to the next gas station, hopefully. Don't make too many hard left turns or you'd have to make a hard right to get that little bit of gas back over to the petcock before it ran dry. Those were the good ol' days, weren't they? "Late for school again, I see?" "Yep, I ran outta gas." "Again?!" "Ahhhh, yeah."
  15. #40
    Apr 2012
    Greenville, SC
    If you figure the true average over a few thousand miles. the slight variation in where you fill too will even out and not matter.
    I recorded every fill-up on Fuelly. Had a nice running average over lifetime of the bike. One goofy fill-up doesn't change things much when you've got 20,000 miles of history
  16. #41
    Clinton, MS
    And you hoped that the reserve space wasn't holding water since it had been so long since you used it.
    2019 RTL Phoenix Orange
  17. #42
    Mar 2017
    Salisbury,NC
    OR...... you forgot to put petcock back on "run" after fill up and was left on "reserve" and when you went to switch it, motor was dead!!!
  18. #43
    Quote Originally Posted by Woodaddict View Post
    I resemble that!
    Faaaarrrr to many times for it to be the slightest bit funny anymore! You'd think I'd learn after the first coupla times, wouldn't you?!
  19. #44
    Active Member slhanks004's Avatar
    Nov 2022
    Gilbert, AZ
    I don't rely on the miles to empty number too much. I have an app on my phone (Fuelio) that I use to keep track of fuel for both my Spyder and my GMC. At each fill up I enter the trip odometer reading, gallons purchased, amount of fuel, and price per gallon. It calculates gas mileage, averages it, etc. Once you know your average range, you know how far you can go on a tank. I've been using it for years. I also know my mileage goes down if am riding mountains or doing 70+ on the interstate or if I'm doing a lot of stop-go city riding.
    The miles to empty reading on the dash is based on some algorithm based on some historical data, and can and does change "in flight".
    Scott (slhanks004)
    Gilbert, AZ USA
    2022 Spyder RT Limited - Carbon Black
    • Pedal commander
    • Baja Ron sway bar
    • TricLED tail lights
    • TricLED driving lights
    • Corbin seat
    • BRP rider backrest
    • Lamonster topcuff (2) w/ RAM mounts
    • 12v/USB docking station
    • Garmin Zumo XT
    • RLS cat delete pipe
    • IPS highway pegs
    • IPS belt tensioner
    2022 RT-L , Carbon black
  20. #45
    Northern Kalifornia
    I never ever made that mistake! LLPOF. Well, maybe once I did. LLPOF again!
  21. #46
    Northern Kalifornia
    Luckily I never did that. LLPOF Well maybe once. LLPOF again.
  22. #47
    Aug 2019
    Stoughton, WI
    I have a 2022 RT STS with only 900 miles on it. So far, averaging only in low/mid 30's mpg 100% solo. Expecting (hoping) it goes up as mileage increases and engine meshes..
    2022 RT Sea To Sky
  23. #48
    Northern Kalifornia
    I've heard of other people only getting mpg in the low 30's on their new machines. On my first tank full I got 40. After that, my mpg's went down into the mid 30's until about my second oil change. Then my mpg's began to rise back up to the low 40's. I've only hit 45 twice but constantly get 40 most all the time. Particularly when I'm 2up. I believe the mpg's pretty much start and end right at the wrist.
  24. #49
    A couple thousand miles and the mileage will get better. Most 1330's get high 30's to low 40's. For me, it was 39-41 most of the time.
    Jul 2023
    Chesterfield SC
    Having a 2011 RT-S I just want to let you know that you are hurting my feelings on MPG. But I do enjoy the high RPMs and the fun factor. The biggest problem is having to stop more often in a group riding situation. But usually at least one in the group has to pee at that time so all is good. lol
    2011 Can AM RT-S SE5 Red
