Results 1 to 17 of 17
    US new jersey
    Default What would cause this issue with shifting on a '21 RT?
    Hi all, a friends RT shifts down at speed, but not with the paddles. The oil has been changed and the bike runs fine. Any advice on what's the possible cause? Thank you.
    Last edited by Peter Aawen; 03-02-2024 at 08:36 PM. Reason: Expanded title to briefly ask the question... ;-)
    About that time/vintage, there were a number of Spyders that had a problem with the Left-Hand Control Module causing problems like this... You might want to do a bit of searching and reading to see if this one fits?!
    Quote Originally Posted by Mosess01 View Post
    My 14 RT has done that since 2014 when I bought it.... The SE trans ( ie. paddle shifter ) is designed to Downshift if / when the RPM's drop below a designed in amount ...... Mike
    Oct 2020
    Arizona
    So you are saying the machine will auto downshift as is slows, however the paddle downshift does NOT work when is used to manually slow the machine or descending a grade?
    Sep 2016
    Chillicothe, Oh.
    The machine will downshift as it slows, but it SHOULD also downshift with the paddle. As Peter said there were some with left hand control module issues.
    2015 RT , Black
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    One way to know if it is an issue with the paddle, do you have a problem shifting to Reverse?
    If no problem shifting to reverse, you may be trying to downshift at too high an RPM.
    2018 RT LTD , Black
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    A different take on the question....
    Mosess stated "Hi all, a friends RT shifts down at speed, but not with the paddles. The oil has been changed and the bike runs fine. Any advice on what's the possible cause? Thank you. "
    I think he meant that it down shifts at a while traveling at a normal speed, where his friend did not slow down and it shifts down by itself. Just my take on the post.
    Last edited by Peter Aawen; 03-03-2024 at 05:45 PM. Reason: Moved Post title - they mess with Searching! ;-)
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
    Durham,Maine
    It will not back shift manually if the rpm's are to high!!!
    2012 RTL , Pearl
    Oct 2020
    Arizona
    Quote Originally Posted by seaweed View Post
    I hope he comes back and clarifies, as I could not figure out what he was saying!
    US new jersey
    yes this is what's happening. and the bike is a 21 RT...with 16k
    Clinton, MS
    i'm more lost than ever now. Who were you replying too?
    2019 RTL Phoenix Orange
    IMHO Mosess Needs to ride that bike to accurately report what the issue is. It's hard enough diagnosing a problem when the actual Operator is telling us, trying to do it Third party ..... well you get my point .....Mike
    US new jersey
    Seaweed, you are correct; the bike shifts down as it should when slowing down, but when trying to shift down with the paddles ss you slow, it does not work. The oil is new, the filters have been replaced.
    I know what you mean, this is the info I received. The bike is being brought up to Artic adventures today.
    It would help everyone A LOT Mosess if you would use 'Reply with Quote' from the bottom right of the particular post you are replying to; or at the very least, identify each poster you are addressing by including their username in the text of your reply, as you've done with Seaweed above and I've done in this post to you ...
    When you don't do either, it becomes very confusing for readers, like listening to just one side of a telephone conversation - and that doesn't help you and it frustrates the heck out of everyone else!
    So please, have the courtesy to make that little effort to help others help you.
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Well I'll be...
    I mean... Well I'll be...
    Sorry. Couldn't resist.
    2021 RT Base - Petrol Blue
    INDIANA, USA
    seaweed you are correct the bike shifts down as it should when slowing down. when trying to shift down with the paddles , It does not work. the oil is new the filters have been replaced.
    I know what you mean this is the info I received . the bike is being brought up to Artic adventures today.
    This post is a little confusing. But hopefully it will work out.
    Let us know what is the fix when you get the answers.
    Thank You and have a Blessed Day. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Active Member Elwood58's Avatar
    Mar 2012
    PHOENIX Arizona
    It almost seems to be low on oil. The Hydraulic Control Module in pretty sensitive to oil level..
    2012 Viper Red RT-S (Sold)
    2020 Ryker Rally
    2023 Plasma Red F3 Limited
