Results 1 to 11 of 11
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    Default Any Suggestions on where to place a Spyder emblem?
    I have two shiny silver Spyder emblems. I'm debating on where to stick these? Does anyone have any pictures of these attached to an F3L ?
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
    Florida Swamp
    Looks like metal.
    You don't have much choice, if they are metal, they will have to go on a flat, smooth area. Not many flat smooth areas on a Spyder.
    2019 F3-S , Black & Silver
    Mar 2022
    PA
    These are plastic. But your point is valid regardless. There are several areas that are flat, but only a few.
    Vermont
    Quote Originally Posted by GRHorst View Post
    HI GRHorst,
    How about on the frunk, or on the saddlebags, or on the trunk( if your spyder has one).
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Bossier LoUiSiAna
    Well you have two so balance it out one on both sides Saddle bags maybe helps keep symmetry for pics & if is using sticky back foam tape like 3m, suggest prep cleaning bag surface with rubbing alcohol, let air dry then apply.
    Feb 2020
    Minnesota,USA
    I've seen them placed on the speaker grills, doesn't affect the music that I know of.
    If in Doubt, Don't Do It!
    Sep 2018
    Australia
    Wherever the most bugs end up or somewhere dark maybe.
    Mar 2022
    PA
    Yes they came with the 3M 2-sided stickies. In holding them up to the bike, the iceberg blue doesn't show them very well. But next to the black on the trunk or the black around the headlights/fog-lights, they show up much better. I never would have thought of putting on the speaker grills. As far as collecting bugs ... well ... hmmm ... cleaning bugs out of these emblems doesn't sound like an enticing task.
    I'll post pictures eventually.
    Mar 2022
    PA
    Default Spyder Emblem Added
    I ended up putting them on the back where they are easier to see and may pick up some headlight glow.
    Vermont
    GRHorst,
    On my previous Spyder (a 2014 RTS-SE6) I had one, and I placed it on the nose of the windshield, between the 2 headlights where it did not block anything.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Mar 2022
    PA
    GRHorst,
    Deanna
    That was a place I considered. I wondered whether it would stay on if mounted up where it picks up more wind. Apparently it stayed on for you.
