Page 3 of 3 FirstFirst 123
Results 51 to 58 of 58
  1. #51
    Quote Originally Posted by shakin_jake View Post
    Where I’m slightly stumped (NOW)… I have a butt load of miscellaneous sockets. I’m trying to find the best fit for the lug nuts. 1st place so far goes to a 6 point 13/16 ths.
    13/16ths is 20.64 mm.
  2. #52
    Feb 2022
    New Zealand
    1st place so far goes to a 6 point 13/16 ths. What are others using to R&R the lug nuts?!?
    + 1 on the 6 point 13/16 socket for the wheel nuts.
    I too went through all my stuff, mostly metric. Nope. I packed another 6 point and removed a nut. Then took the nut down and tried the complete range of 6 pointers at a local Engineering Supply shop. The 6 point 13/16 is the one I paid for and bought home.
    I crack the nuts before I lift.
    2017 F3 Ltd
  3. #53
    Active Member shakin_jake's Avatar
    Nov 2011
    north central Fla.
    As for balancing, I accomplish electronic dynamically balancing. The fronts easily fit my Snap On automotive balancer. I use the “fine” setting which is within 1/10 ounce. That alone, when done correctly is a very smooth ride. A few years ago, I purchased a used set of Centramatics for the front from someone here, or maybe EBay.
    Correctly dynamic balanced tires with the Centramatics also is one of those changes you just forget you did it. So smooth and combined is better than balancing alone.
    ~~~~I’m a bit late getting back to this thread. Duty calls doncha know. Nice that you have access to a Snap On automotive balancer. I used my Marc Parnes balance system which is not a high speed balancer such as your Snap On equipment. That said, I found that both tires and rims needed very little in the way of stick on tire weights. One wheel only needed 5 grams (1 tape-a-weight) and the other took 10 grams or 2 tape-a-weights. Needless to say (but I’m Jake like that) each tape-a-weight segment when weighed on a gram scale comes out to 5 grams.
    On to the test ride -
    I call it a test ride since this is the very first time mounting and balancing Spyder wheels & tires for me, and I’ll also echo what you said about for most Spyder owners, it’s easier to take both front wheels to a tire dealer and let them R&R the tires and handle the balancing. If I didn’t say it before I’ll say it right now. These were the hardest motorcycle rims I’ve ever handled when it comes to removing and replacing tires. I actually enjoy doing this type of work using hand tools, but not on the Spyder wheels. The lack of the typical deep V section in the center of the rim is what made this a joyless job for me. I read where you said you used short moto tire irons and didn't find it an arduous task. All I can say is, you’re a better man than me Gunga Din.
    Moving along, the first ride on the new rubber was conducted well into the night and it was raining to boot. Couldn’t ask for a better test bed IMO as I was able to observe how well these tires handled wet traction and they were impressive. Balancing felt spot on rolling southbound on Highway 441 at the posted speed limit of 65 MPH. I basically used County roads, 318 from my driveway to 441 South then West on County Road 326 until I got on the interstate, I-75 north back to County Road 318 then home. What I found traveling in excess of the posted speed limit on I-75 (70 MPH), once I hit 80 MPH I noticed a bit of imbalance in the front. The balance seemed off rolling out at 80 + MPH yet when I slowed down to 70 MPH, all was well again. Post ride pontifications, I felt that a true high-speed balance was in order yet the next time I had the Spyder out, and had just to run some errands, using I-75 coming back from Ocala (I used 441 South to get into town), running upwards of 90 MPH in short blasts when and where permissible, and the pronounced imbalance was gone. To say I was a bit astonished, true that! A third high speed run on another different day the results were the same, the detectable imbalance was missing. I have to conclude that what transpired was a bit of scrubbing of the tires during the initial ride had removed what, some type of Joo-Joo? I’m guessing the tires scrubbed themselves in. Whatever happened, I’m thoroughly enamored with Vredestein Quatrac tires (175/55/15) that are now on the front of my 2021 Can Am Spyder RT Limited. Compared to the OEM Kendas riding the roads I ride in North Central Fla., I honestly can’t say the Vredesteins are marginally better tires because, in my experience, I’ve never found the OEM Kenda tires lacking, yet I want to emphasize that the majority of roads I travel are string straight. That said I have a layout of local roads I can use that will put stress on any tire, a combination of local roads with a downhill left turn that if you try to take the corner going faster than 15 MPH you’ll either low side, high side or worse, on two wheels. I can take that same corner a little faster on both the Spyder and the Ryker Rally I had, but what I want to stress is that I never encountered a situation with the OEM Kendas that those tires couldn’t handle with aplomb.
    All that said I have to believe others here that have less than complimentary results when pushing their F3’s and RT’s through the Dragon and similar roads on OEM Kenda tires. I’m sure I’d have similar experiences, yet the roads I ride, the OEM Kendas have been more than adequate. Now that I have a pair of a Vredsteins on the front of my Spyder I have an idea they will impress the hell out of me. So far so good. No regrets switching over to an automotive tire on Cretin Girl. Others may have better and different ideas.
    Best,
    Jake
    Reddick Fla.
    We always like a bit of volume- Phil Campbell Motörhead
    2020 Rally , Black
  4. #54
    Happy to hear you like those Vredestein's ..... as to the " motorcycle RIMS " .... All Spyders have " J " type rims / wheels which are AUTOMOTIVE rims / wheels .... Rims for TWO wheel Mtc's have a different classification per Gov"t. regs .... If you get a chance ( or have to ) ride in the wet let us know what you think ..... just a note - I know tires and have discovered & recommended the best and most popular auto tires used by members here .... and over the course of a decade+, I have said upgrade to Auto tires .... AFTER .... you wear-out the Crapenda's .... unless they are Defective ( which is not un-common ) and unsafe .....Mike
  5. #55
    Nov 2011
    north central Fla.
    Happy to hear you like those Vredestein's ...If you get a chance ( or have to ) ride in the wet let us know what you think .....
    ~~~Mike, my first ride on the Vredsteins were/was in the wet. It was raining at the time. Not a gully washer but very wet none the less. Wet traction was excellent. Same with braking & induced quick right to left and vice versa steering inputs at 65 MPH. Total confidence in these Vredestein tires!
    Quote Originally Posted by blueknight911 View Post
    ~~~I just don’t have the hatred you and some others have shared with Kenda tires. I get it, you don’t like them and or had bad experience with them. That’s happened with other major brands of tires through the years. Anyone remember the Firestone fiasco that owners of a certain Ford SUV had with their OEM firestone tires? I don’t recall how many people lost their lives running OEM Firestones on their Ford SUV (I can’t recall which model of Ford SUV off hand). Hold on, I just looked this up-
    <snip>
    Unusually high failure rates of P235/75R15 ATX, ATX II, and Wilderness AT tires installed on the first–generation Ford Explorer and similar vehicles caused crashes that killed 238 people and injured around 500 others in the United States alone; more died in other countries.
    <end snip>
    ~~~I guess my point is this Mike, most every tire manufacturer has some problems, Kenda has been no different in having problems with the tires they sold to Can Am. That said, they have made a lot of good Kenda tires for our Spyders too. I can’t and won’t complain about Kenda tires as my experience with them have been stellar. Of course, others may have better and different ideas
    Best,
    Jake
    Reddick Fla.
    Even a blind squirrel finds a nut every once in a while
    2020 Rally , Black
  6. #56
    <snip>
    <end snip>
    Best,
    Jake
    Reddick Fla.
    .... I just don't have the HATRED you and some others have shared with Kenda tires .......
    - I don't know where you got this .... I HAVE NEVER used that word in any reference to KENDA tires ... The construction of the Kenda tires for Spyders is barely sufficient for their weight; plus they have the highest DEFECTIVE TIRE rates of any tire currently being made that I know of.... I have been sharing my knowledge (from actual schooling) about tires here for over a decade, and so far, my track record for picking Auto tires for Spyders is un-matched ...... Mike
  7. #57
    Durham,Maine
    that's right!!!
    2012 RTL , Pearl
  8. #58
    Feb 2022
    New Zealand
    just a note - I know tires and have discovered & recommended the best and most popular auto tires used by members here .... and over the course of a decade+, I have said upgrade to Auto tires .. AFTER .... you wear-out the Crapenda's .... unless they are Defective ( which is not un-common ) and unsafe .....Mike
    After ya wear them out? Yeah Nah, not for me. I biffed these with plenty of tread left. Not worth it.
    The performance was abysmal compared to the replacements. Perhaps if you have no corners near ya but here its all corners. I reckon if your looking for better cornering and handling and it dosnt break the bank its a no-brainer.
    First ride I had a smile on my face. Pressures set with Peter A's advice. Yup, worth every penny.
    Then came that sway bar and links, even better.
    I reckon the icing on the cake for me was the PedalBox to wake up the nanny inspired slumbering 1330 at lower revs.
    No more downshifting 2-3 cogs from a cruise speed to get some power to complete a manoeuvre.
    These are the tyres I removed. I offered them free to anybody who wants them locally.
    Pick em up or I can drop them off if passing by. Not surprisingly there were no takers.
    2017 F3 Ltd
