Results 1 to 11 of 11
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Default Any hints on changing FOBO 2 Sensor Max PSI Settings?
    I need to change the max PSI setting for the rear tire. I read the manual and couldn't find how to reset if you want. For some reason it is set at 29 PSI max. Any help would be appreciated.
    Last edited by Peter Aawen; 01-30-2024 at 04:12 PM. Reason: Expanded title to briefly ask the question... ;-)
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    Aug 2019
    Stoughton, WI
    Thought you just opened the app, go to rear tire and adjust the recommended/max setting?
    2022 RT Sea To Sky
    Jun 2018
    Pahrump NV
    Troop, Thanks. I figured out.
    Quote Originally Posted by Bangorbob View Post
    Any chance of telling the rest of us?
    Clinton, MS
    Click on the wrench/Screwdriver at top of screen. Click on tire position and current settings. Adjust the scroll wheels where you want (upper limit, set pressure, lower limit) and click save. All done.
    2019 RTL Phoenix Orange
    Harrington, Australia
    Just an addition, EdMat. Unless it has been changed, when you “save” the new settings, you have to position your phone next to the tyre stem for update and then press save. That is a pain on the rear tyre. I haven’t changed settings in years, which is why I don’t know if this step is still required.
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2018
    Pahrump NV
    Edmat explained well.
    Pete, I will going out in about 1 hr and try all this stuff and report back if having to hold near sensor is needed.
    Clinton, MS
    As long as you are within 40 or so feet of the bike it will take............ed
    Jun 2018
    Pahrump NV
    I just finished setting and airing my tires. Didn't need to put phone next to sensor for any reason.
    Wonderful, thanks for that, Bob. It means I will no longer have to dig out my copy of the Kama Sutra to rehearse the moves required to place the phone on the rear FOBO while pressing save.
    HeliBars Handlebars
    Kenda Kanine rear.
    Thanks Ed, much appreciated
    HeliBars Handlebars
    Kenda Kanine rear.
