Results 1 to 8 of 8
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    Default Looks like the 2024 F3L gets 5 position heated grips?
    I notice that BRP now has the 2024 owners manuals for on road product. As I have an F3, I wanted to check out the features of the 2024 model
    https://www.operatorsguides.brp.com/...Series.WEB.pdf
    I did notice that the heated grips on the F3L appear to have a 5 heat position drivers grips. I believe only the RT series up to now had multiple heat settings for the drivers grips.
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
    Mar 2013
    Marion, Arkansas
    I wonder if this is something that will retrofit on the earlier F3 models?
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    May 2013
    Apex, N.C.
    Wow, the RT only has 3 levels (high, low, and off). My BMW had 5 levels and then off, and I loved them. My F3L only has the on and off setting. It is better than nothing, but really lacking when temps get below 40.
    Durham,Maine
    The kill switch in that picture is what caught my eye also, three steps to that also? If it works the way it's explanted, you could get messed up with that center position!
    2012 RTL , Pearl
    Active Member AndysF3S's Avatar
    Jul 2023
    Alberta
    Quote Originally Posted by Ex-Rocket View Post
    If it can be retrofit to the earlier models like my 2022 F3S it would IMO actually be "considered" as a handle bar warmer. I had the on/off version installed by the dealer and they are almost useless compared to the skidoo handlebar warmers.
    indpls in
    It looks as if that is now the start button also, just like my cvo.
    Last edited by Peter Aawen; 01-28-2024 at 02:07 PM. Reason: Fixed quote display ;-)
    Vermont
    My current 2023 F3 LTD Special Series only has on/off settings on the heated hand grips.
    Deanna
    Current Spyder - 2023 F3 LTD Special - Mineral Blue
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Front Fairing Service Access Door Covers (Carbon Fiber Domed Black)
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    A-arm Daytime Dual Color LED Running Lights with Blinker Module
    Marinco 12 Volt Power Receptacle with polarized leads & slide lock
    Show Chrome Trunk Shock
    LED'S - Run/Turn/Brake Rear
    Former Spyder - 2014 RTS SE6 Cognac - SOLD
    First Spyder - 2012 RTS-SE5 Quantum Metallic Blue - TRADED UP
    Very Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Warm hands would be nice.
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
