Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
  1. #26
    Active Member RangerRick's Avatar
    Jul 2022
    Coos Bay, Oregon
    175/55R-15 Vredestein Quatrac SL on the front first of the week
  2. #27
    Vermont
    2014 RTS-SE6
    Front tires: 165/60 R15 Continental Contiprocontact
    Rear tire: 215/60 R15 General Altimax RT 43 running 26 PSI
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  3. #28
    Oct 2015
    Lynden, WA
    2017 F3T Se6
    Front tires 175/55R-15 Vredestein Quatrac SL 18psi
    Rear tire General Altimax RT43 215/60R 15 22psi
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  4. #29
    Dec 2018
    Elanora, Qld, Australia
    2020 F3Ltd, Rabbit (Sydney) sway bar.
    Third set of Kendas fitted yesterday, early because of a long three week ryde coming up.
    Mixed riding, vigorous 75%, local and freeway 25%.
    Fronts 17PSI and over 30k Km between changes.
    Rear 22-24 PSi with 20k km between changes.
    For two-up ryding the rear tyre is adjusted higher to Spyder manual specs.
    Very happy.
    Update: Following a few long overnighters and 6742km Black Dog ride my rear is now down to 20PSI with the fronts on 17PSI. Kendas are serving me well with grip and acceptable life, not less than shown above.
    There is usually another way. 2020 F3Ltd.
    2020 F3 Ltd , Brake Pedel lowered. Liquid Titanium
  5. #30
    Mar 2015
    Fritch, Tx
    Spyder: 2014 RTL
    Type of Riding: Mostly day rides up to 350 miles & running local errands. Not terribly aggressive.
    Suspension: RonBar, Laser Alignment
    Front Tires: Kenda OEM 165/55/15, set to 20 PSI
    Rear Tire: Yokohama Avid Envigor 205/65/15, set to 26 PSI
    Current Mileage: rear 9400 miles. Middle is done. Fronts still have some life left at 18K
    Comments: Changing front and rear at 18031 with Hankooks -- Kenergy S Touring on the rear -- Ventus V4 ES on the front.
    EDIT/extra comment: I figure the poor mileage on the Yokohama was due to the higher pressure I ran. The edges still looked new while the middle was worn to the bars. Going to run these Hankooks at a lower pressure to see what happens.
    Here are the Hankooks.
    Last edited by Peter Aawen; 07-31-2022 at 01:46 AM. Reason: Removed reference to post no longer shown... ;-/
    Those who say " I can't" will always be right.
  6. #31
    Active Member Fjrwillie's Avatar
    Jul 2015
    Mass
    Spyder: 2015 RT-S 82,000 Miles
    Type of Riding: Touring, Nationwide Scavenger Hunts, Aggressive from time to time
    Suspension: Stock
    Front Tires: Kenda Kanine K20 20#
    Rear Tire: Kenda Kanine K20 30#
    Current Miles: Rear tire shot @ 15,100 miles, Front still going @ 15,100 OEM's ran about 25,000 to 26,000 miles so expect at least that from these
    Comments: Rear tire replaced with Riken RAPTOR HR 215/60R15 this week
    The Future is Not Today (Motorcycle Blog) http://nomadwillie.blogspot.com/ IBA 32847
    2015 RT-S
    2015 RT-S , White
  7. #32
    Please, this thread is JUST for members to post up the details of what tires they are running & how successfully for all to see, preferably in the style/format shown in the first post of the thread/as used by Fjrwillie & CruisinTx above -
    NO OTHER DISCUSSION will be allowed to remain!
    We don't want to dilute the value of the thread as a detailed resource/list &/or let it degenerate into juuust another tire thread that's branching off into talking about tires & brands & treads & pressures, or whatever, it is JUST for members to post the details as outlined of WHAT they are using in the format shown! And no matter how hard it is to resist the temptation, ANY other discussion &/or recommendations should be taken elsewhere or conducted via PM! IT IS NOT ACCEPTABLE HERE!
    Thank You!
  8. #33
    Jun 2022
    N.E. Fl
    Spyder: 2016 F3-T 45000+ miles
    Type of Riding: Mostly touring. Not terribly aggressive. Solo
    Suspension: OEM
    Front Tires: OEM 18psi
    Rear tire General Altimax RT43 215/60R 15 20psi DIY installed yesterday
    Current Mileage: About 115 miles.
    Note: Speedo and GPS are now the same! Ride is Smooooth...
    2016 F3-T , Blk/Rd
  9. #34
    Oct 2020
    Washington
    Have Federal Formoza AZ01 on the front. Sweet spot is 28PSI cold. 165 55 15
    Rear OEM Kenda. Soon to replace with General Altimax RT45 215 60 15
    Lvmyspyder
    She's Lisa
    2018 Spyder RT Limited[img]
    2018 RTL , Stock Brake Pedal Extender. White
  10. #35
    Mar 2021
    Maryland
    Spyder: 2020 F3 SE6
    Type of Riding: Touring/Mountain Roads/Spirited
    Suspension: BajaRon SwayBar, Wilbers Front and Rear Shocks
    Front Tires: Vredestein Quatrac 165/60/15
    Rear Tire: Vredestein Quatrac 205/60/15
    Current Miles: Front and Rear about 10K
    2020 F3 SE6
    2020 F3 , Black
  11. #36
    Active Member robtdonna's Avatar
    Ellijay, Georgia, United States
    OEM tires so far, rear is about ready to be replaced.
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
  12. #37
    Active Member Reacher68's Avatar
    Jul 2018
    Grand Prairie, TX
    Spyder: 2016 F3-T
    Type of Riding: Mostly solo, Touring and aggressive and/or spirited
    Suspension: Baha Ron sway bar, Elka front shocks, Laser Alignment
    Front Tires: Vredestein Quatrac 5 175/55 R15 - Set to 18psi
    Rear Tire: Yokohama Advan Fleva v701 205/55 R15 - Set to 28psi
    Current Mileage: 25,552 as of Saturday
    Comments: My OEM rear tire made it to about 12k miles and even though the fronts were fine, I changed them all out. After 13k miles on the setup listed above, the fronts are still in great shape and corner amazingly well. The Yokohama on the rear, however, did not have the traction I hoped and did not hold up well. I'm now on the hunt for a new rear tire.
    2016 F3-T
    Places I've ridden.
  13. #38
    Nov 2019
    Central Oregon
    Spyder: 2015 ST Ltd
    Type of Riding: Day trips and touring.
    Suspension: RonBar, front springs upgrade on the way
    Front Tires: Vredestein Quatrac 175/55 X 15
    Rear Tire: Kenda
    2015 ST Limited; Givi E52 Top Case; Baja Ron anti-sway bar; Cal Sci wind screen; Vredestein Quatracs (Front).
  14. #39
    Nov 2018
    Des Moines IA
    2020 Sypyder RTL 49,000 miles
    Type of riding: Mostly solo. Local and distance riding. Love the curves.
    Suspension: Stock shocks and Baja Ron sway bar
    Rear tire: 215/60R15 RIKEN RAPTOR HR 6,500 miles running 24 PSI
    Front tire: 175/55R-15 Vredestein Quatrac SL 15,400 miles running 18PSI
    2020 Spyder RTL - Blue
    2018 Spyder ST Limited , Asphalt Gray
  15. #40
    Feb 2023
    WI
    Default K20 tires
    I just put on a new K20 on my 2017 RTS. I will let all know next year as to how they hold up. So far the rear tire is exceptionally smooth and has great grip.
  16. #41
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Spyder: 2019 RT-L
    Type of Riding: touring
    Suspension: Baja Ron Bar and end links; Laser Alignment
    Front Tires: ContinentalProContact 165-60-15 on order
    Rear Tire: Original Kenda
    Current Mileage: 3891 Front to be installed as soon as they get here Rear - 3891 miles.28 psi looks to be wearing in middle so adjusted to 25 psi
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
  17. #42
    Vermont
    2023 F3 LTD Special Series( Still new bike)
    Kendas Radial
    Front Size: 165/55/R15 @ 15.5 PSI
    Rear Size: 225/50/R15 26.0 PSI
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  18. #43
    Jun 2023
    FL
    Spyder: 2014 RT-Limited 9,000 Miles
    Type of Riding: New rider - around town, planning to tour. Always ride 2 up
    Suspension: Stock
    Front Tires: 175/55R-15 Vredestein Quatrac, 18 PSI
    Rear Tire: 205/60R-15 Vredestein Quatrac, 19 PSI
    Current Miles: < 50
    Comments: Installed this past week by West Coast Powersports of Clearwater, FL. Immediately could feel significantly increased stability and handling. Great on wet pavement. Tires purchased through Tire Rack - great service, great price. These tires replaced the 10 year old OEM.
    2014 Spyder RT Limited
    2019 Honda PCX150
    Sarasota - Tampa
  19. #44
    Wa.
    My '22 RTL running the stock tires that came on it.
  20. #45
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    Now I'm going to upset everyone I'm sure.
    OEM Kendas, front and back. 20/28 psi.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
  21. #46
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    2018 RTL
    Type of Riding: Mostly touring. Not terribly aggressive. 2-up 50%
    Suspension: Stage 2 Elka Shocks (Front set) Stock shock (Rear)
    Bajaron “anti” Sway Bar with Blue links
    All my tires were just installed for spring of 2024 so 0 miles so far.
    FRONT: VREDESTEIN QUATRAC 165/60R15 16-18 PSI FRONT
    REAR: VREDESTEIN QUATRAC 205/60R15 18 PSI REAR
    Freedom Trailer Tires: COKER TIRE set MICHELIN® XZX 145/70 R 12 XZX 69S TL
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
