Fuel pumps installed in production on some Model Year 2021 and 2022 Can-Am Ryker
Some fuel pumps sold in service that may have been installed on Model Year 2019 to 2024 Can-Am Ryker. Possible impacted part numbers include:
709 000 810
548 874 036
709 001 261
219 800 529
"The fuel pump impeller could swell and cause the fuel pump to stop working."
"Upon BRP's investigation into the matter, it found that one of its suppliers had changed raw materials used in the impellers in its fuel pumps over the course of their manufacture. It went from a first source to a new source, then eventually back to the first source. The new source, they found, can cause the impeller to swell in use, which could cause it to interfere with the fuel pump housing, thus causing the fuel pump to stop working properly."
I called BRP who instructed me to call my dealer. As I had installed a replacement pump recently, I wanted to know if the replacement might be bad. The dealer service tech told me that affected fuel pump serial numbers are in the range 079 to 176 (first three digits). Hard to tell from the photo, but mine starts with a 2.
"BRP will inspect and, if necessary, replace the fuel pump at no charge to you (parts and labor). "
I suspect the "inspection" will be to check the fuel pump serial number. Although 10,000 MAY be affected, I suspect the actual number of replacements will be considerably less.
This is the second replacement fuel pump on my 2019 Rally. The original failed about a year ago, the replacement just a few weeks ago.
Reason: Expanded title to briefly state the reason for this thread! ;-)
My Rally is subject to the recall. The dealer is ordering replacement parts but they won't be available until Feb at the earliest. Thanks for the heads up :-)
Hello Dick B, I do not believe the number that is stamped into the white plastic on top of your fuel pump/fuel level unit is the part number. The "BRP P/N --- --- ---" is the nine digit number listed on the top of the attached white paper stick on info tag that includes a UPC bar code. I checked my wife's 2021 fuel pump tonight and the number on her attached fuel pump/fuel level unit tag matched up with the first (top) BRP P/N listed in the recall letter that we received yesterday and as posted above in your comments that shows the correct four different part numbers in question. My wife's 2021 Ryker 900 ACE number is one of the possibly faulty fuel pumps in question - 709 000 810. Everyone should check the BRP P/N tag on their pump top by the fuel line exit. I wonder just how many have actually had issues or may or not be faulty?
I try to always use "Ethanol Free" gas in anything with what I consider to be "small engines" (especially if carbureted) that I get at a local gas station almost all of the time before we ride. Ethanol does a number on some materials, especially rubber parts. The ethanol attributing to this Ryker fuel pump issue is just my educated guess at this point since we have not had any issues with my wife's Ryker, but then it only has 1,100 miles on it, which might make a difference also. I like to follow the philosophy of "Don't fix it if it ain't broken", especially if the replacement has issues also. I just hope BRP obtains fuel pumps that will not have any such problems.
I had no "red dust of death" or apparent problems with the drive sprocket/pulley on my 2016 F3T but had them change it anyway as per the recall. So far all is well. Well, take care, be safe, and well. Think SPRING for us who live in the NE because I am getting anxious to ride at 77 years old and it still never gets old.
2016 F3 T , Fabricated adjustable brake rod Intense Pearl Red
I brought mine into the dealer in Medford, Or. this morning. They've looked at several Rykers the last couple weeks, mine being the first they've found in need of replacement. It's in the garage until they can get the parts they need.
Update:
After the dealer replaced the fuel pump for the recall the "miles to empty" function stopped working properly.
Prior to the replacement I'd use that display to know when to refuel rather than depending on the fuel gauge. I rode to Crescent City, Ca last Saturday filling up 3 times for the round trip of 300 miles. At each fillup miles to empty would read in the 80s with a full tank then after riding 20 or so miles on the highway it would jump to low 90s, then after 30 or 40 miles back to 84 or 86. Then back up to 90 or so. I called the dealer, he has the bike for the week while wife and I travel out of town. He called BRP support, they suggest reflash the ECM. He's thinking of replacing the fuel pump assembly again. I'll repost if or when it gets resolved.
