Page 72 of 80 FirstFirst ... 2262686970717273747576 ... LastLast
Results 1,776 to 1,800 of 1999
  1. #1776
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Do you have any pictures of the installed lights?
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
  2. #1777
    Active Member Poppie65's Avatar
    Jul 2023
    Springfield, OH
    Thanks Pete, I wouldn't guess that the Nanny would be so particular with wheel rotation, but i thank you for the heads-up. As for the brakes, we were certainly conscious of the rotors and calipers, and as such there wasn't any significant contact with either that we felt could have collapsed the cylinders enough to warrant a full pedal of movement. Are these caliper pistons/hydraulic system softer than the typical automotive brake system?
    2023 S2S
    Shoei RF-1400 Helmets
    Cardo Freedom 4x comms
    Both riders USMC vets
    2023 Sea to Sky , Green Shadow
  3. #1778
    Jul 2023
    Springfield, OH
    Front view from inside the garage showing the AA A-arm lights, mirror mounted lights, and the light mounted under the lip of the frunk:
    Front view from outside with engine running and headlights on:
    Side view showing the mirror mounted lights, and the fender lights:
    Double Flags on rear trunk:
    Turn signal and shift paddle mod:
    2023 S2S
  4. #1779
    Quote Originally Posted by Poppie65 View Post
    For someone not used to them, Brembo brakes, especially those on our Spyders, do feel a little different to the brakes most are used to with their cars & trucks etc... Some call it a 'softer' feel; some feel it takes a 'longer pedal/lever throw until they start to bite'; some just feel it takes more pedal movement to get any braking action, but then there's little progressive feel, once they grab they just REALLY brake; while others have completely different 'feelings' & terms for them/the way they work, but for most, they do work well and they are widely considered to be a massive shed load better than the previous brakes on the 2012 & earlier Spyders! And when these Brembo Brakes are teamed with a very good Nanny, like that on our Spyders, then largely because of the larger tire footprint area Spyders have over most bikes; the Brembo's excellent braking effectiveness; and the much lighter weight of a Spyder vs that of most things fitted with similar brakes, then if you/the rider knows how to use the pedal to get the best from them, they will pretty much stop your Spyder vastly better/quicker than just about anything else on the road!!
    Regardless of what you call it/how you describe it, it'll take very little disc/pad movement to produce what feels like a much greater 'loss of pedal'! What you've mentioned re the brakes isn't an uncommon thing with Brembo brakes, even if they aren't on Spyders; and it is almost impossible to take the front wheels off a Spyder without moving the discs a little, which means they'll be pushing the pads clear of the discs juuust a tiny amount.... So just that action of removing the wheel is often more than enough to let the pads move away from the discs a seemingly miniscule amount, something that's compounded exponentially if you do happen to noticeably touch &/or drag the disc a bit as the wheel comes off - and even that miniscule amount of additional clearance between disc & pad can give you what feels like a massive loss of pedal!!
    But if, as is most likely given what you've told us, Poppie, that's all it is in your case, then simply making sure you apply the brakes a couple of times after refitting the wheels and before turning the ignition on will likely mean you never experience a 'brake failure' warning for the same reason again.... Altho there's still the possibility of the brake fluid level in the reservoir being down juuust a tiny amount thing that can cause similar warnings; or the pressure switch getting a bit of mud on it & not working properly; or your foot touching the pedal as you ride; or the....
    Just Sayin' Ride Safe, & have a Great New Year!
  5. #1780
    Jun 2023
    Tennessee
    Very nice!
  6. #1781
    Aug 2019
    Stoughton, WI
    What type of material did you use on your paddle shifter pads?
    2022 RT Sea To Sky
  7. #1782
    Sebring, FL
    I do like it Poppie, if I only lived closer to Springfield OH.
  8. #1783
    Jul 2023
    Springfield, OH
    I purchased the products that are discussed in this tread.
    https://www.spyderlovers.com/forums/...ig-improvement!
    2023 S2S
  9. #1784
    Jul 2023
    Springfield, OH
    Thank you sir.
    This is the time of year to live in Fla though!
    2023 S2S
  10. #1785
    Aug 2019
    Stoughton, WI
    Got my Lamonster Tail Brighter lights installed today.
    2022 RT Sea To Sky
  11. #1786
    Mar 2021
    Maryland
    Got back in from a ride and noticed a rubbing whine from the belt as I was pushing my spyder back into place in the garage.
    Looked and noticed the belt was all the way to the left on the rear sprocket. Jacked the rear up off the floor and took a reading off the drive belt with the kricket. 110 FT-lbs.
    So I figured the belt was new as my whole rear swing arm had been replaced from the rear end accident and the belt has "stretched" from wear in so I go to adjust the tension and the alignment and find the rear axle nut is tight but not the 166 ft/lbs it should be as I could take two fingers on my 1/2 in ratchet and just spin the nut off.
    Got my belt tension back up to 180 ft/lbs and aligned the belt. I got out the ole torque wrench and brought the axle nut up to 160. Hopefully there should be no other issues. Going out for a new years eve ride with some friends during the day tomorrow I'll see how it holds up.
    2020 F3 SE6
    2020 F3 , Black
  12. #1787
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    Installed stealth taillights look great
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
  13. #1788
    Jun 2023
    Tennessee
    I tried the Eco mode today on the way to the Liquor store, for a bottle of Champagne. Meh! I guess it'd be OK using that mode in the city maybe, and long stretches of highway with little traffic.
    Happy New Year
  14. #1789
    Member vulkus's Avatar
    Dec 2022
    QLD, Australia
    Finally got a new battery, my old one died, I think it was the original. If so, it was 8 yrs old.
    That battery bracket is a real pain though, got it in its home eventually though.
    2015 Spyder RT Special series Se6
    Really a mutant cross between a special series and a Limited.
  15. #1790
    Feb 2022
    very southern tip of Texas
    Installed a BajaRon anti-sway bar with Lamonster end links this evening. Used aluminum ramps attached to my F150’s rear bumper to get the nose up the required ~24”. Further safety measures were a floor jack under the center spine, and ratchet straps and a rear wheel chock to keep things from rolling back. Just in case the parking brake and SM6 tranny in 1st gear weren’t enough! Straight-forward install with great instructions. Haven’t ridden it yet, but can tell a big difference just rocking it side to side on the garage floor.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
  16. #1791
    Member ZiggyF's Avatar
    Aug 2023
    Florida
    It was a dreary & cold day here yesterday in Central Florida so I finally got around to a little mod I had on my list. I never cared for the grey windshield bracket.
    2014 Can Am Spyder RTL Chrome Edition
    Led Headlights & Fog Lights
    Frunk Organizer
    Rear Trunk Organizer
    Painted Windshield Bracket Black with Chrome Spyder
    Leather Like Foam Hand Grips
    Handlebar Weights
    Plug N' Play Brake Light Flasher / Modulator Kit
    Trunk Mounted Run, Brake & Turn Signal LED Light Kit
    USB/Volt Meter
    Led Undercarriage Lights
    Show Chrome Full Size Brake Pedal
    Show Chrome - Chrome Handlebar Cover
    UltraGard Essential Half Cover
    Polished Stainless Steel License Plate Frame
    KEMIMOTO Motorcycle Bottle Holder
    Bluetooth 5.0 FM Transmitter
    Hopnel Trunk and Saddlebag Cargo Net System
    TackForm Center Mount Phone Holder
    Trunk Mount Dual Flag Holder
    High Way Pegs
    Baldwin Ironworks Cat By-pass
    K & N Air Filter
    Magnetic Mirror Mounts
    2-WDG Motorcycle Seat Cushions
    Kenda Kanine Tires
    Originally from Medina, Ohio
    Currently living in The Villages, Florida
  17. #1792
    Sebring, FL
    Hi Zig, Sebring here, I'm guessing around Lakeland for you.
  18. #1793
    Aug 2023
    Florida
    I’m in The Villages
    Frunk Organizer
    Handlebar Weights
    USB/Volt Meter
    High Way Pegs
    K & N Air Filter
    Kenda Kanine Tires
  19. #1794
    Member fuzzyspyder's Avatar
    Oct 2023
    Colorado
    We finally had a decent day here in western Colorado. Temps mid 40’s and sunny, just a slight breeze. Not bad for mid January. My apologies to the middle country and East coast folks in the brrrrrr areas.
    So Christmas Eve I decided I would go for the Baja Ron sway bar. I liked the option of buying it from Lamonster because his links don’t require the spacers. Just a tad easier to install. It didn’t ship until after New Years but that was clearly stated on his site. Didn’t expect to install it until maybe March, but it was nice, so what the hey.
    I used two ramps on the tailgate of my truck to get over 24” of clearance. Actually had like 28” since I was alone and not sure how far up the ramp to go. My ramps are only 6’ so there was a pretty big incline, but the Spyder climbed like a champ and the E brake held it until I got down and put the rubber chock behind the rear wheel.
    Being 70 and not really liking the ground anymore (getting down is easy, getting up, not so much), I took my little silicon tool tray with all the tools the install vids said I would need and a couple extras. Razor knife, needle nose pliers, my push pins assortment kit and tool - Just in Case.
    Install was a breeze. No issues getting any of the bolts out or back in. Did break a push pin, so the needle nose pliers and one new push pin came in handy.
    Okay, so would I do it again? Absolutely. Took “Cool Change” for a 10-15 mile ride and it was awesome. Way less body roll and we have a crowned street that I hated to take it on because it leaned so bad. Took it there and it was much more stable. Corners way better and the ride is maybe better although that may be in my head. Steering is still easy and all in all, a great upgrade.
    Current Ride: 2019 Can-Am Spyder F3 Limited - Cool Change.
    Past Rides:
    2014 HD Triglide - Fat Bottom Girl
    2006 Honda Gold Wing GL1800 - Jessica
    2003 Honda Gold Wing GL1800 - Helga
    2014 HD Ultra Limited - Harley Quinn
    2008 Honda Gold Wing GL 1800 Trike w/Champion Conversion - Fat Bottom Girl 2
    2001 Honda Gold Wing GL1800 - Tweety
    2015 HD Triglide - Fat Bottom Girl
    2011 HD Ultra - Raven
    2006 K1200LT - Vianca
    2007 HD Ultra
    2006 HD Ultra
    2004 Honda Goldwing
    2001 Honda Goldwing
    1996 Honda Goldwing
    2000 Honda Aero
    1985 Honda V65 Magnum
    1992 HD Softtail
    1976 HD Sportster
    1973 HD Sportster
    1965 HD Sportster
  20. #1795
    Mar 2021
    Maryland
    Things have been cold and the baby has been on the maintainer. And as usual Ice on the ground for my birthday. Gave myself a birthday present , ordered the cat delete bypass pipe and Tric led afterburnerz lights for better rear visibility. Now just waiting on the garage to come up above 40 degrees so I can install the lights.
    2020 F3 SE6
    2020 F3 , Black
  21. #1796
    Mar 2021
    Maryland
    Quote Originally Posted by Dasmoetorhead View Post
    Happy New Year
    Where you will find eco mode great and I found out about this while I was in your neck of the woods when I was in storms going to the Cherohala Skyway outside of Blue Ridge City GA on the way to Tellico Plains in 2022.
    I use ECO mode as my "Rain Mode", turn this on while in the rain and it will help with keeping the rear tire from breaking loose and hydroplaning. Especially with going up and down that hilly terrain with water ponding up and rolling down the hill at you in downpours. It rained on me every *#%!ing day on that trip and the last 2 days I couldn't even take my rainsuit off until I was about 2-3 hours away from home.
    Last edited by Peter Aawen; 01-23-2024 at 01:56 PM. Reason: Fixed attach display ;-)
    2020 F3 SE6
    2020 F3 , Black
  22. #1797
    Aug 2019
    Stoughton, WI
    Installed my Show Chrome large brake pedal. Only 12 more things to install before riding season
    2022 RT Sea To Sky
  23. #1798
    Jul 2023
    S.E. Pennsylvania
    Took off one front fender before dinner in preparation for installing sequential turns signals on the bike tomorrow. Will reinstall the fender tomorrow, then take the other fender off and repeat the process.
    Lee B
    2022 Can Am RT Limited
    2021 Honda NC750X DCT
  24. #1799
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Lee0123 View Post
    I did the fender lights on my F3S by jacking up the tires and removing the wheels. Likely repeat it with my S2S.
    2022 RT Sea To Sky
  25. #1800
    Sep 2020
    San Antonio Texas
    Quote Originally Posted by Mazo EMS2 View Post
    Just what it says really...I see this question/topic on a couple other forums I visit, and it's always interesting to see what people post. So, what did you do to your Spyder today? Any model, heck let's include Ryker too.....
    Have an upcoming ride this Sunday 1/28/2024 with the Blue Knights INTERNATIONAL LE MC, San Antonio, Tx. Alamo Chapter IV, heading to La Vernia TX, Blessing of The Bikes. All bikes are welcome. Check Facebook Blue Knights TX IV San Antonio for more info.
    I was out pre-checking my Spyder for the ride, fluids, tire pressures, and anything needing my attention. Saturday I'll take my Spyder out to clean up for Sunday's ride. Oh yeah, I sat on my Spyder. Yep, I'm ready.
    2016 RTS SE6 , Orbital Blue
