Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. #26
    Faribault, MN
    Davgill, just who or what were you disagreeing with? The last posts before yours was from 07/02/19 - 10/19/19 4 years ago??? No fumes on my '18 RTL with a BIW Cat Delete. Is your F4 windscreen vented and is the vent open? I went the extra mile and Titanium Header wrapped my front tuned pipe and the Cat Delete , but you still can't easily wrap the joints/gaskets.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  2. #27
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    If you change muffler, cat delete, cat bypass, etc, the ECU after idling a few minutes will REMAP itself!
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  3. #28
    Aug 2019
    Stoughton, WI
    IF any ECU changes are made, it would also do it while riding.
    2022 RT Sea To Sky
  4. #29
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Quote Originally Posted by Don'tPanic View Post
    I just installed a cat delete pipe from Baldwin Iron Works on my F3-S - it came with a spring removal/installation tool and a baffle. I was reluctant to get this seemingly useless farkle, I've read all the research I could get my hands on about the exhaust back pressure, and everything that goes into designing the exhaust system, the importance of the catalytic-converters, and how countless engineers spent millions of dollars and spilled gallons of their brain matter over the design to make it perfect, and how nothing you can do will improve anything, because they are PhDs and you're nobody.
    What a bunch of B.S. !!!
    ...oh man, the sound! What a sound! I had a grin on my face the entire ride to work and back. I giggled like a little girl accelerating through the underpasses with a roaring exhaust reverberating under the bridges.
    The spyder now performs the same way in the "eco" mode as it did in normal mode. I'm actually scared to turn it off. There's a seriously noticeable performance boost. I can't wait to take it out for a ryde again.
    I left the stock muffler on, so the sound is not obnoxious, it's just enough louder and a lot deeper. The engine braking produces this deep gurgling sound that sends shivers down your spine and makes you want to engine brake again
    I swear that vibrations are almost completely gone, the machine now runs smooth like a butter.
    The only downside - the exhaust now stinks... but who cares, it's behind me!
    This is an older post, but I concur with your evaluation. Why did I wait so long.
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
  5. #30
    Member Postleg's Avatar
    Mar 2024
    North Carolina
    The Cat delete, lessened vibrations?
    Due to nerve damage, I'm quite sensitive to vibrations through my arms.
    Could you say where the felt vibrations were lessened?
    Thanks!
  6. #31
    Jun 2023
    Tennessee
    I feel the bike is less buzzy. Where I used to ride in 6th gear, I'm now running in 5th or even 4th gear, and the engine feels more relaxed.
Tags for this Thread
