Results 1 to 8 of 8
    Dec 2022
    Florida
    Default So, there's no more cam sensor on '22 models?!
    So I decided to hook up my Pico-scope to get some waveforms and save them for reference; looked at the wiring diagram but can't find the "caps" cam sensor. Code P0340 says it's pin D4, but to my surprise, my 2022 has no wire in D4! I went to the engine and there is no cam sensor!!! So, one less problem to deal with. But that means you can't fire coils in direct mode, only waste spark. Exactly 2 sparks in 720°. The bad thing will be that we're not able to diagnose any cam and crank correlation....
    Last edited by Peter Aawen; 11-16-2023 at 07:30 PM. Reason: Expanded title to briefly state the reason for this thread! ;-)
    The 1330 had cam sensors through the 2022 models. At least that's what the parts fisch shows. Rotax dropped them for the 2023 models. Curious, to be sure.
    Dec 2022
    Florida
    Mine is a '22, built in March.
    Jan 2021
    Descanso, CA
    mandytuning -- the shape of your waveforms is not what I was expecting. Where are you getting your inputs? Thanks.
    Dec 2022
    Florida
    Back probe the ECU, the waveform is like any 36-2 with reluctor type sensor.
    Jan 2021
    Descanso, CA
    Okay the Blue trace is CPS and the Red trace must be coil primary to ECM. I've proposed earlier ECMs using the MAP signal when the CAPS fails but now I'm thinking they are actually shifting into wasted-spark mode. And the new ECMS are always in that mode. An improvement. Thanks for posting waveforms.
    Feb 2016
    The 2023 RT shop manual still shows them...
    2020 RT Limited , Marsala Red
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    My old Hondas (400/4 F2) and other motorcycles of that vintage had wasted spark, firing every 360 degrees.
    I image sparking in the exhaust stroke helps clean up the emissions a little bit helping with Euro-5 or similar perhaps.
    On the other hand it might be to reduce build costs? Who knows for sure?
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
