What do you do to Secure your RT 622 At Hotels?
I am curious as to what methods you use to secure your trailer when you leave it behind at a hotel.
Using some sort of a hitch lock seems simple enough, but I was wondering if you do more than that to secure it, so it is there when you return.
Reason: Expanded title to briefly ask the question... ;-)
A long vinyl covered cable with loops on each end wrapped through the frame and locking it around a light pole works well. Seen it used many times.
I’ve seen a few people use a tire boot. But most everything is just a deterrent. If someone really wants it they have the skills to defeat and take. I use a lock brass hitch lock
I use a vinyl covered cable and wrap it through one wheel and around my trailer tongue and lock it. This way it can't be rolled away. That and a hitch lock keeps honest people honest. That's about all you can do.
![](https://www.spyderlovers.com/forums/maps/map.png?states=CA.OR.WA.NV.ID.UT.AZ.MT.WY.CO.NM.ND.SD.NE.KS.OK.TX.MN.IA.MO.AR.LA.WI.IL.MI.IN.KY.TN.MS.OH.WV.AL.ME.NH.VT.MA.RI.CT.NY.NJ.PA.DE.MD.VA.NC.SC.GA.FL)
I would use a vinyl covered cable and add an alarm padlock. Cables are harder to cut w/ bolt cutters and the alarm lock (~$17.00 on Amazon) emits an ear piercing 110db shriek if it's shaken (like when the cable is being cut).
Another option, or addition, is and Apple tracker (or similar) hidden in the trailer. If someone makes off w/ the trailer, you, ALONG W/ LAW ENFORCEMANT, can track it on your phone.
Just an idea.....
2020 Spyder RT Limited; Deep Marsala/Chrome
Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
General Altimax RT43 215/60/R15 on factory rear
Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
Extra LED lighting and misc. to suit my needs/wants
![Quote](images/misc/quote_icon.png) Originally Posted by Copperman
This is what I have done..... hitch lock plus cable around a pole. Then I always try to park it within sight of the front desk and tell the attendant that I'm locking and leaving the trailer for a period of time. Never a problem.....
But keep in mind, two guys and a pick-up truck can have the cable cut and trailer loaded in mere seconds. Make sure your insurance policy is up to date.
Semper Fi
![](https://www.spyderlovers.com/forums/maps/map.png?states=WA.ID.MT.WY.CO.UT.TX.NM.AZ.NV.CA.OR.OK)
Our neighbors had their camp trailer stolen right out of their campsite in a commercial campground during the day while they were away. It can happen at any time anywhere to anyone if you don't take precautions.
I've used a 622 trailer since 2012 and take 3 to 4 trips a year where I need the extra storage. I use a hitch lock, park it as close to the entrance as possible, I don't expect hotel personnel to watch it (not their responsibility) and don't worry about it. Haven't had an issue in 11 years. Comment #8 is the first time I recall anybody posting about a trailer being stolen and it wasn't a can am trailer.
I do like the idea of putting an apple tracker in it.
Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
2012 RTL SE5 Lava Bronze - 19,675 miles
A hitch lock along with a chain and pad lock attached to a light pole.
I like the cable system, but I already had a chain.
The only peace of mind is a current insurance policy!
Current Ride: 2019 Can-Am Spyder F3 Limited - Cool Change.
Past Rides:
2014 HD Triglide - Fat Bottom Girl
2006 Honda Gold Wing GL1800 - Jessica
2003 Honda Gold Wing GL1800 - Helga
2014 HD Ultra Limited - Harley Quinn
2008 Honda Gold Wing GL 1800 Trike w/Champion Conversion - Fat Bottom Girl 2
2001 Honda Gold Wing GL1800 - Tweety
2015 HD Triglide - Fat Bottom Girl
2011 HD Ultra - Raven
2006 K1200LT - Vianca
2007 HD Ultra
2006 HD Ultra
2004 Honda Goldwing
2001 Honda Goldwing
1996 Honda Goldwing
2000 Honda Aero
1985 Honda V65 Magnum
1992 HD Softtail
1976 HD Sportster
1973 HD Sportster
1965 HD Sportster
Like others here, I have used a chain to secure it to a pole, railings, etc. But, if someone really wants it…….
