Results 1 to 25 of 28
    Clinton, MS
    Default SOLVED - Show First Unread Post search going to First Post in thread instead?
    Noticed something weird about this thread:
    https://www.spyderlovers.com/forums/...26%23129324%3B
    When you click on go to the first new post it goes to the original first post in the thread, not to the unread part. This has happened on three separate occasions so its not a one time deal. All the other threads are behaving normally.
    Last edited by Peter Aawen; 11-16-2023 at 06:09 AM. Reason: Put the right link in there! :opps:
    2019 RTL Phoenix Orange
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    Noticed something weird about this thread. When you click on go to the first new post it goes to the original first post in the thread, not to the unread part. This has happened on three separate occasions so its not a one time deal. All the other threads are behaving normally.
    Same thing for me. I was hoping that Peter Aawen would fix it.
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
    Quote Originally Posted by seaweed View Post
    Innterrrresting, but not Funny!?
    I would certainly try to fix it for you if I could, but it's not happening like that for me & I can't see any difference between this & any other thread's address &/or control parameters that might make it do that??
    Have you cleared your cookies & history lately, or maybe closed off the Forum completely & then re-started with a fresh login?? I wonder if doing that would change anything for you?? Otherwise, I'm not at all sure why it'd be doing this bit; nor how this could possibly even happen, not unless the cookie/history address for this particular thread on both your devices has somehow been corrupted so that your machines are only reading the first part of the thread address - the bit that takes you here:
    instead of here:
    https://www.spyderlovers.com/forums/...09#post1691109
    Nb: That second address above should take you to seaweed's post #18 instead of PJveetwin's post #1! Seaweed's post was the first unread post in the thread when I opened it last time, and it was just easier to use that address rather than any other.
    Dec 2020
    Hartwell, Ga
    instead of here:
    Not only those two but mine also. I have cleared my history & cookies recently but will try to log out then back in to see if that does it.
    Dec 2020
    Hartwell, Ga
    I have logged out and back in and also cleared cookies, history and cache, I'll see what happens whenever anyone else post's here.
    Clinton, MS
    No luck
    Feb 2022
    New Zealand
    No luck
    FWIW Its fine my end.
    Dec 2020
    Hartwell, Ga
    Still going to the 1st post for me. The good thing, or strange, is that it's only this one thread.
    Still can't find anything, but what I might do is move all the posts from THIS thread:
    discussing this issue into a Forum Support Thread, and once they're all there, let's see if it changes which thread it happens on then??
    Still can't find anything to cause the 'Show First Unread Post' search to send some of you to the Opening Post in this thread & apparently only in this thread, but I've moved all the posts discussing this out of THIS thread and over to a NEW thread - shown below:
    https://www.spyderlovers.com/forums/...thread-instead
    The New thread is in Forum Support & Testing section; so can those of you affected please check that thread out too, in order see if it's changed which thread the dodgy Show First Unread Post thing happens to you in then - and then tell me the results of your check in the Forum Support Thread (linked above) please??
    Clinton, MS
    Carries me to the bottom of this one, still to the top of the original thread................ed
    Thanks for that. It might not achieve very much for you, but it narrows down the search somewhat for me!
    Oct 2015
    I think that the answer is: That gremlin that wanders all over the world infecting Spyders at random, only this time it was spyderlovers.com!
    2015 RT-S SE6
    My Mods:
    Mar 2015
    Fritch, Tx
    Happened for me; clicked on go to first unread message and got sent to the first message. Using a HP lap-top.
    Those who say " I can't" will always be right.
    Sorry people, with everything else that's been going on here (altho I do hope that you haven't been subjected to it or noticed it too much! ) I haven't really had all that much in the way of time to chase this further today (and it's now almost 21:30 here in South Oz! ) but with any luck I'll be able to dig deeper tonight/tomorrow morning; altho from what little I've seen so far, I'm really thinking this is gonna be well beyond my pay grade, access, & abilities! So I suspect that I'll be handballing this one up the line very soon...
    But please do post up any info you think might help or changes that occur to your access if they happen, every little bit helps.
    Ps: Anyone want to add a new post to the original thread so I can try it under my own login/privileges again?? It's been a coupla minutes since I saw any new posts in there - I've added the correct link to the OP up the top here, so it should be easier to find now.
    Clinton, MS
    Here is a test post for you Peter. Clicking on go to the first unread post on this thread carried me to the original post still.
    Clinton, MS
    Clinton, MS
    Ps: Anyone want to add a new post to the original thread so I can try it under my own login/privileges again?? It's been a couple minutes since I saw any new posts in there - I've added the correct link to the OP up the top here, so it should be easier to find now.
    Left one for you.
    Mod Edit: Copied it into this thread too - see just above your post ^.
    Left one for you.
    As you should be able to see, I copied your post in the other thread back into this one too, just so I could check out another possibility.... But the bad news is that I STILL can't see any reason for it doing that 'go direct to opening post' thing for you; it still went straight to that latest post for me when I clicked on 'View First Unread', just like it always does in every other thread when I do the same....
    Apart from the Moderator Privileges that I have (which are applied elsewhere, so shouldn't have any impact on this sorta thing?? ) our profiles are, for all intents and purposes, set up the same way?!
    Anyhow, I've made a little change to the thread itself this time, then posted up in that thread... so can you please check it out and see what happens for you now?? Reply here to, I don't think there's any point in keeping PJ's thread this much off topic for any longer than we already have done.
    Thanks Ed, I replied in the other thread, but please check out what happens after this post & check in to see if anything has changed if you post it up in the other thread - the one in Forum Support.
    Sorry about all this PJ - as soon as I get a response from Ed in the other thread telling me what happened when he tried to read this post in this thread, I'll get these couple out of here & hopefully your thread can go back to discussing automated mailed tickets that are for places when you weren't there!
    Dec 2020
    Hartwell, Ga
    This thread is now working as it should for me.
    Dec 2020
    Hartwell, Ga
    The original thread now works as it should for me.
    Oct 2015
    Same for me. The gremlin is now gone!!
    2015 RT-S SE6
    My Mods:
    Feb 2012
    Spring City,Utah
    I just went to the mentioned post and all worked for me as it should
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Clinton, MS
    Works as it should now. Your touch of magic did the trick................ed
